Hi All,
I am using the Arduino Mega 2560 in combination with the Seeedstudio CAN-BUS Shield V2.0.
Library v1.0.0 (older version)
https://www.arduinolibraries.info/libraries/can-bus-shield
I am trying to create a test device which I connect to a CAN module and request some data.
When the tested CAN module is decoupled and a new one is attached which is defective or not connected at all, then the old CAN messages are still present when reading the CAN message with
CAN.readMsgBufID(&id, &RecMessageLen, RecMessage.U8);
Is there a way to clean the buffer?
Or should I set them all to Zero before reading the MsgBufID?
Is anyone with the change to library v2.3.0, would it improve this part as well?
Edit: tried the new library version, normal operations, that version is working with the Raspberry version as well..
Thanks.
This is for now done with the default demo "receive_check":
#include <SPI.h>
#include "mcp_can.h"
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
while (CAN_OK != CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k
Serial.println("CAN BUS Shield init fail");
Serial.println(" Init CAN BUS Shield again");
delay(100);
Serial.println("CAN BUS Shield init ok!");
unsigned char len = 0;
unsigned char buf[8];
if(CAN_MSGAVAIL == CAN.checkReceive()) // check if data coming
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
unsigned long canId = CAN.getCanId();
Serial.println("-----------------------------");
Serial.print("Get data from ID: 0x");
Serial.println(canId, HEX);
for(int i = 0; i<len; i++) // print the data
Serial.print(buf[i], HEX);
Serial.print("\t");
