Here's the code
#include "CMAP.h"
//matrix declarations
int d;
unsigned char char_pointer;
char Display_Ram[38];
unsigned char mask;
char LED_DATA1[]= " NO OBJECT DETECTED ~";
char LED_DATA2[]= " OBJECT DETECTED ~";
char count;
unsigned char shift_counter;
//ping declarations
const int trigger=4;
const int echo=3;
float distance;
#define INTEN 6500
const char CLK = 5;
const char DAT = 6;
const char STR = 7;
const char K0 = A0;
const char K1 = A1;
const char K2 = A2;
const char K3 = A3;
const char K4 = 8;
const char K5 = 9;
const char K6 = 10;
const char K7 = 11;
pinMode(CLK, OUTPUT);
pinMode(DAT, OUTPUT);
pinMode(STR, OUTPUT);
pinMode(K0, OUTPUT);
pinMode(K1, OUTPUT);
pinMode(K2, OUTPUT);
pinMode(K3, OUTPUT);
pinMode(K4, OUTPUT);
pinMode(K5, OUTPUT);
pinMode(K6, OUTPUT);
pinMode(K7, OUTPUT);
digitalWrite(K0,HIGH);
digitalWrite(K1,HIGH);
digitalWrite(K2,HIGH);
digitalWrite(K3,HIGH);
digitalWrite(K4,HIGH);
digitalWrite(K5,HIGH);
digitalWrite(K6,HIGH);
digitalWrite(K7,HIGH);
for(d=0;d<32;d++)
clock();
strobe();
d = 0;
pinMode(trigger,OUTPUT);
pinMode(echo,INPUT);
void loop(){
ping();
void ping(void){
// Trigger US-100 to start measurement
// Set up trigger
digitalWrite(trigger,HIGH);
delayMicroseconds(20);
// Start Measurement
digitalWrite(trigger,LOW);
distance=pulseIn(echo,HIGH);
distance=distance*0.0001657;
if(distance >= 0.01 && distance <= 0.30){
for(int x=0; x<=350;x++){
Display();
shift();
else{
for(int y=0; y<=5; y++){
Display();
shift();
void shift(void)
int x;
for(x=0; x<38; x++){
Display_Ram[x] = Display_Ram[x+1];
shift_counter++;
if(shift_counter == 6){
shift_counter = 0;
load2();}
else{
load1();}
void Display(void)
mask = 0x01;
scan();
digitalWrite(K7,LOW);
for(d=0;d<INTEN;d++){}
mask = 0x02;
scan();
digitalWrite(K6,LOW);
mask = 0x04;
scan();
digitalWrite(K5,LOW);
mask = 0x08;
scan();
digitalWrite(K4,LOW);
mask = 0x10;
scan();
digitalWrite(K3,LOW);
mask = 0x20;
scan();
digitalWrite(K2,LOW);
mask = 0x40;
scan();
digitalWrite(K1,LOW);
mask = 0x80;
scan();
digitalWrite(K0,LOW);
void load1(void){
char counter1;
if(LED_DATA1[char_pointer+1] == '~')
char_pointer = 0;
for(counter1 = 0; counter1 < 5; counter1++){
Display_Ram[32 + counter1] = character_data[(LED_DATA1[char_pointer] - 0x20)][counter1];
Display_Ram[37] = 00;
char_pointer++;
void load2(void){
char counter1;
if(LED_DATA2[char_pointer+1] == '~')
char_pointer = 0;
Display_Ram[32 + counter1] = character_data[(LED_DATA2[char_pointer] - 0x20)][counter1];
char_pointer++;
void Clear_Display_Ram(void){
unsigned char rcount;
for(rcount = 0; rcount < 37; rcount++)
Display_Ram[rcount] = 0xff;
void scan(void){
for (count=32;count>(-1);count--){
if ((Display_Ram[count] & mask) == mask)
digitalWrite(DAT,LOW);
digitalWrite(DAT,HIGH);
clock();
strobe();
void clock(void){
digitalWrite(CLK,HIGH); // clock hi
digitalWrite(CLK,LOW); // clock low
void strobe(void){
digitalWrite(STR,HIGH); // strobe hi
digitalWrite(STR,LOW); // strobe low
