Clear display on serial monitor
When I'm running a new sketch the serial monitor may have stuff already, or be printing stuff when I open it.
Is there a simple way to run in setup that would clear the current display?
What I do now is put a delay so that I can click on the "clear display" button.
Because the Serial monitor does not support control code such as clear screen the best that you can do is to put a Serial.println() in a for loop to print numerous blank lines which will cause whatever is on the screen to scroll out of sight
A proper terminal emulator will allow you to use control sequences to clear the screen, position the cursor, etc
Try this: Serial.print(F("\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n")); the "n" is the new line character. When it reaches the bottom it scrolls the onscreen data off the top. You can do it in a loop if you want.
Given ESC-H/ESC-J is "home/clear screen" from VT100 days:
  Serial.print("\n"); // CRLF
  Serial.print("\h"); // HOME
  Serial.print("\j"); // CLRSCR
void loop() {}
The IDE protests the unknown (unsupported) escape sequences.
C:\...\sketch_mar12a.ino:4:16: warning: unknown escape sequence: '\h'
   Serial.print("\h");
C:\...\sketch_mar12a.ino:5:16: warning: unknown escape sequence: '\j'
   Serial.print("\j");
Could we move this to the IDE2 section as a suggestion?
As the question is not specific to either IDE it has been moved to Project Guidance
I’m glad nobody has suggested CLS yet :clown_face::sunglasses:
Maybe
  Serial.print("\033h"); // HOME
  Serial.print("\033j"); // CLRSCR
void loop() {}
Two tiny "boxes" for unknown character.
I see the Serial Monitor like a printer... without "home" or "clrscr"
On serial monitor, yes. Like @UKHeliBob said above, serial monitor doesn't understand these codes and there is no way to clear it except clicking the clear button. But these codes should work on a terminal emulator app (set to vt52 mode).
I have used similar (vt100) codes in Arduino sketches before. They never work in serial monitor, but when I use terminal window in Ubuntu and the screen command, it worked great.
