Clear LCD but only once a loop
Hello folks. I want to use the large fonts to display a rotor heading of an antenna, eventually. But for now I have a button connected so that if I push it, it displays a “1” and if not a “0”. Problem is if I don’t clear the lcd when you display the 1 it still displays part of the 0 because it’s bigger. So I thought , well I’ll just clear the lcd. Yes but then all you get is a flickering 1 as it is trying to clear the display each time through the loop. How do I just get it to clear it off to display the 1 while pushing the button, so I get a nice solid 1?
Thank you.
Code…
A set of custom made large numbers for a 16x2 LCD using the
LiquidCrystal librabry. Works with displays compatible with the
Hitachi HD44780 driver.
The Cuicuit:
  LCD RS pin to D12
  LCD Enable pin to D11
  LCD D4 pin to D5
  LCD D5 pin to D4
  LCD D6 pin to D3
  LCD D7 pin to D2
  LCD Vee tied to a pot to control brightness
  LCD Vss and R/W tied to ground
  LCD Vcc to +5V
  LCD pin 15 tied to pushbutton for control of backlight
Made by Michael Pilcher
2/9/2010
// include the library
#include <LiquidCrystal.h>
const int buttonPin = 7;
int buttonState = 0;
// initialize the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// the 8 arrays that form each segment of the custom numbers
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
// loop counter
int x = 0;
  // assignes each segment a write number
  lcd.createChar(0,LT);
  lcd.createChar(1,UB);
  lcd.createChar(2,RT);
  lcd.createChar(3,LL);
  lcd.createChar(4,LB);
  lcd.createChar(5,LR);
  lcd.createChar(6,UMB);
  lcd.createChar(7,LMB);
 pinMode(buttonPin, INPUT);
  // sets the LCD's rows and colums:
  lcd.begin(16, 2);
void custom0()
{ // uses segments to build the number 0
  lcd.setCursor(x, 0); // set cursor to column 0, line 0 (first row)
  lcd.write((byte)0);  // call each segment to create
  lcd.write(1);  // top half of the number
  lcd.write(2);
  lcd.setCursor(x, 1); // set cursor to colum 0, line 1 (second row)
  lcd.write(3);  // call each segment to create
  lcd.write(4);  // bottom half of the number
  lcd.write(5);
void custom1()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1,1);
  lcd.write(5);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.setCursor(x+2, 1);
  lcd.write(5);
void custom5()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1, 1);
  lcd.write((byte)0);
void custom8()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(5);
 void loop(){
  buttonState = digitalRead(buttonPin);
  if (buttonState==HIGH){
    lcd.clear();
    custom1();
  else {
    custom0();
/code]
Not that hard. Remember to always keep track of where you are. So create an extra variable. Call it oldState or something you like better. Compare buttonState with oldState. If they are the same, do nothing. If they aren't the same, clear the LCD and update oldState.
That's all.
Ah ha, OK that sounds good. I'l give that a try. Thanks!!
Upon trying it, I am not sure how to code it. I get the concept, which I think is a good one.
This new comparison has to be outside of my loop to update?
I am not sure what to put in there yet.
While we are at it, I figured out how to read my analog pot and print the result on the LCD. But how do I take my value and print it using the large fonts?
The values of 1 and 0 were a little easier, but how do I print 155 for example?
No, it is inside the loop.
Declare the new variable in void.setup.
And before you write anyhting to the display, check if it’s not already there.
This would result in something like this:
The Cuicuit:
  LCD RS pin to D12
  LCD D4 pin to D5
  LCD D5 pin to D4
  LCD D6 pin to D3
  LCD D7 pin to D2
  LCD Vcc to +5V
2/9/2010
int oldState = 0;                                  //<- new line
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
// loop counter
int x = 0;
  lcd.begin(16, 2);
void custom0()
  lcd.write(2);
  lcd.write(5);
void custom1()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(5);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.write(5);
void custom5()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.write((byte)0);
void custom8()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(5);
 void loop(){
    if (buttonState!=oldState){             //<-
    oldState=buttonState;                   //   New or
    lcd.clear();                            //   altered lines
    custom1();}                             //<-
  else {
    custom0();}                             //<-
Wow that works like a charm, of course you knew that! ha…
I didn’t understand that you could put an if then another if right after it.
So does that translate into IF the buttonstate is HIGH then AND if buttonstate not equal to oldState or is that more like an OR…???
So also this only happens if it’s HIGH then it skips and goes to the next ELSE. But what is happening when you ask if buttonstate is not equal to oldState but then you right away make it equal to it? What is that doing in plain language?
I don’t know if that’s clear but I hope so.
Thanks
    custom1();}                             //<-
  else {
    custom0();}                             //<-
}/code]
This is an AND, not an OR situation.
If you see a pressed button, AND you haven’t processed it before, process it now.
As you are ending that processing with the accolade } twice ,the ELSE belongs to the first IF statement, not to the second one.
You can easily keep track of that by using the indents, with which the IDE helps you by automaticly using those.
IDE also helps you with the () parentheses and {} accolades by showing you which pair belong together.
Ok I think I understand that. The fog is clearing a little. ;)
Any thoughts on the large font for my pot value? I suspect that might be more complicated??
I really don't have any ideas on that at this point. I will keep at it and keep searching.
Thanks again!!
There's another technique that doesn't involve as much programming.
Instead of clearing the entire screen all you have to do is cover up the old number with spaces before writing the new number.
This involves positioning the cursor twice as many times but is still faster than clearing the whole screen and typically doesn't cause screen flicker.
Don
Ok that sounds like a good idea as well and I did see something like that in a search awhile ago.
Anyone have ideas on the best way to convert my sensor reading value to the large font text?
Thanks.
Could I take my sensor reading which I converted to 0-360 then make it a string, grab the values from it and make them variables to print the large font character that I have set up to use those variables to print. See down below where it uses custom(1) for example to print a large font 1.
Such as potValue = 145 so A=1 B=4 C=5 Then use my custom(A) to print a 1? Can I insert a variable in there??
I have this code to read my pot,
// These constants won't change.  They're used to give names
// to the pins used:
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
char outputValueChar[3];
  // initialize serial communications at 9600 bps:
  lcd.begin(16,2);
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  outputValue = map(sensorValue, 0, 1023, 0, 360);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(outputValue);
  lcd.setCursor(0,1);
  lcd.print(outputValue);
  delay(250);
  lcd.clear();
  // wait 2 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
  delay(10);
  Serial.print
and I have this code that so far will print large fonts when I push my button. Now I need to combine them to print my pot reading in large font.
This is the code for the large font…
2/9/2010
int oldState = 0;
int pot = A0;
int potval = 0;
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
// loop counter
int x = 0;
  lcd.begin(16, 2);
void custom0()
  lcd.write(2);
  lcd.write(5);
void custom1()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.write(5);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.write(5);
void custom5()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.write((byte)0);
void custom8()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(5);
 void loop(){
  potval=analogRead(pot);
    custom1();}                             //<-
  else {
    custom0();}                             //<-
Anyone??
I'll have a shot at it. You've got a pot that reads 361 degrees ? You are mapping it from 0 (the first value) to 360, and that results in 361 values. Most pots can be turned about 270 degrees. If you are going to convert, make sure you've got it right. But that's not what your question was about.
You want to break down your value to separate characters. I'm not sure as i haven't played with that yet, but i think you can convert your value to a string. Once you've done that, you can break the reuslt down into separate characters. Those are then sent to your printing routine. You can find extensive information about String (capital S) in the reference part of this site. It will take some reading and studying, but i think this is a way to do what you're after.
Well the pot doesn't go 361 degrees of course, but it's position will indicate a direction from 0-360 degrees. I mapped the input to 0-360. It's for a position sensor on an antennas rotor. The needle is too small to see and I want to make large 7 seg displays to display it.
I have started to look at the String info but still have to get through it.
Thanks.
Anyone with some code that does this?
