Clear oled screen when button isn't pressed
Hi everyone,
I have been trying to get my OLED display to show a picture while a button is pressed but, I want it to clear when it is not being pressed but I am not seeing how I could do that.
here is the code that i am using
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeMonoBoldOblique24pt7b.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define bitmap_height   128
#define bitmap_width    64
static const unsigned char PROGMEM bitmap[] =
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xff, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xf8, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x1f, 0xe0, 0x0f, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x3f, 0x80, 0x07, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x07, 0x80, 0x7f, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x7c, 0x00, 0x07, 0xc0, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0xf8, 0x00, 0x03, 0xc0, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x03, 0xc0, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x01, 0xf0, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x03, 0xe0, 0x00, 0x03, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x03, 0xc0, 0x00, 0x03, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x07, 0xc0, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x07, 0x80, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0f, 0x80, 0x00, 0x01, 0xe0, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x01, 0xe0, 0xff, 0xff, 0xe0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x01, 0xe0, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x01, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    Serial.println(F("SSD1306 allocation failed"));
    for (;;); // Don't proceed, loop forever
  // Clear the buffer
  display.clearDisplay();
void showBitmap(void) {
  display.drawBitmap(0, 0, bitmap, bitmap_height, bitmap_width, WHITE);
  display.display();
  if (digitalRead(13) == 1) {
    showBitmap();
    if (digitalRead(13) == 0)
thanks in advance for solving my problem which will probably have an easy fix
  if (digitalRead(13) == HIGH) {
    showBitmap();
  else {
If you are interested to know why your current code does not work (and you should be) and you haven't figured it out yet, please ask.
    showBitmap();
Have you got a pulldown resistor in place keeping the input pin in a known stat at all times ? You should consider using INPUT_PULLUP in pinMode() for the input pin to activate the built in pullup resistor. You will need to adjust your wiring to take the pin LOW when the button is pressed and the program logic needs to regard a LOW state as indicating that the button is pressed
Note that pin 13 on many Arduinos is used by the built in LED so may not be the best choice fot an input pin
okay this still didn't work but not sure what you want me to change about the wiring specifically i have changed my pin to pin12.
#include <SPI.h>
#include <Wire.h>
pinMode(13, INPUT_PULLUP);
  // Clear the buffer
  display.display();
  if (digitalRead(12) == 1)
    showBitmap();
this is my code now and i have added 2 screenshots of my wiring in wokwi
  • get rid of the resistor on pin 12
  • change the wiring so that pin 12 is taken LOW when the button is pressed
  • test for pin 12 to be LOW when the button is pressed
When using the type of pushbutton that has 4 pins, one pair of pins is permanently connected together inside the button, and the other pair is also permanently connected together. But one pair is not connected to the other pair until the button is pressed. It's often difficult to know or remember which pins are permanently connected. So when you connect wires to the pins, there's a chance you could get it wrong and the button will not work.
You can use a multimeter to check which pins are permanently connected and which are not, before you connect the wires. But there's an easy trick to avoid needing to do that: always connect your wires to a diagonally opposite pair of pins.
for whatever reason it is not working no matter how i connect the button
Try printing the state of the input before testing it. Does the state change when the button is pressed ?
yes it does but for some reason i can't get it to go from a 1 when it isn't pressed to a 0
So what is its normal state and what does it change to when you press the button ?
why don't you verify the function of the button without the OLED code and make sure you understand how it works?
report the value read from the button pin
its normal state is 1 and if the button is pressed it goes to 0 but even if I change the code to show the screen when the button is 0 it won't clear the display when the button goes back to 1 which comes back to my original question
Please post the sketch that you refer to as having been changed
do you need to do a "display.display()" even after "display.clearDisplay()"?
this is the full changed code:
#include <SPI.h>
#include <Wire.h>
  pinMode(12, INPUT_PULLUP);
  // Clear the buffer
  display.display();
  Serial.println(digitalRead(12));
  if (digitalRead(12) == 0)
    showBitmap();
Yes, you do. display.clearDisplay() only clears the Arduino memory where the image is drawn, it doesn't update the oled.
So...
won't have any (immediate) effect.
