Clear sketches
Hello
I'm kinda new with Arduino, just bought an Arduino Uno. I put a program on it that I need for my project. I used the Arduino Uploader, because I had to upload a .hex file.
Now my question is, how do I remove the program from the flash memory :s? I accidentically installed an older version of the program. Does it overwrite eachother every time or do I have to remove te program first..
Thanks in advance !
You don't need to clear between uploads. Each time you upload, the previous sketch will be replaced.
If you're not cautious when uploading the hex file, your bootloader can be replaced.
fuh:
I can put the bootloader on it again by the Arduino 0022 Software, can you tell me what bootloader it is, in case my bootloader is gone?
Got the Arduino Uno with ATMega328p :smiley:
If you're burning hex by the command line i assume you've got some ISP.
For the 328p UNO the bootloader can be found in /hardware/arduino/bootloaders/optiboot/, the file is named optiboot_atmega328.hex; don't forget to unlock and lock when finished bootstraping.
