Clear the array and re-store the new value in array
Here is the code which I did. I want a function that can return to the beginning of the void loop().
Now If I press the '#', the array had been set to empty which is what I expected. But it did not save the value to the array after I press the key again. As I know, the loop() will execute the function in order. So, I do not know why it is not let me put value into the array again after I empty it.
#include<Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
unsigned int time;
// Array to represent keys on keypad
char Keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
// Connections to Arduino
byte rowPins[ROWS] = {6, 7, 8, 9};
byte colPins[COLS] = {10, 11, 12, 13};
// Create keypad object
Keypad customKeypad = Keypad(makeKeymap(Keys), rowPins, colPins, ROWS, COLS);
int theArray[4] = { 0 };
byte arrayIndex = 0;
int guess = 0;
	// Declare pins as Outputs
	pinMode(stepPin, OUTPUT);
	pinMode(dirPin, OUTPUT);
  char customKey = customKeypad.getKey();
  if (customKey)
    Serial.println(customKey);  // print the key i pressed
  if (customKey == '1' || customKey == '2'|| customKey == '3'|| customKey == '4'|| customKey == '5'|| customKey == '6'|| customKey == '7'|| customKey == '8'|| customKey == '9'|| customKey == '0')
    if (arrayIndex < 5) // If the array length smaller than 5, save the pressed value in array
      theArray[arrayIndex] = customKey - '0';
      arrayIndex++;
   if (customKey == '*') // after the array is reach enough length, press '*' to print the array out
    int guess = (1000 * theArray[0]) + (100 * theArray[1] + (10 * theArray[2]) + theArray[3]);
    Serial.println(guess);
   if (customKey == '#') // press '#' to set the array empty
    memset(theArray, 0, sizeof(theArray));
    arrayIndex == 0;
    return 0;
  // here I want a function that can return to the beginning of the void loop()
  // The problem is after I press the '#', the array had been set to empty "0"
  // But It did not save the value to the array after I press the kay again
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Why not--?
arrayIndex = 0;
//return 0;
since @GolamMostafa has found your error, instead of the above, consider (see ASCII)
   if ('0' <= customKey || customKey <= '9')
and instead of
consider doing following with each numeric key press
guess= 10*val + customkey-'0';
where guess is a global and is process/reset when '*' or '#' are pressed
For a full explanation see Keypad data entry. A beginners guide
Why is your array is of type int?
A keypress ( 0 to 9) in the Keypad returns ASCII code which being subtracted by '0' gives a byte value. For example: pressing Key-9 gives 0x09 (0x39 - '0' = 0x39 - 0x30 = 0x09).
I think you want: if ('0' <= customKey && customKey <= '9')
yes, thanks
Is not the following a Logical Style?
if(customKey >= '0' && customKey <= '9')
It is much more logical (and readable) in my opinion, but there are those here who prefer to put the constant value first in comparisons so that where = is used by mistake instead of == the compiler reports an error
wouldn't the following (if possible) be easier to understand
'0' <= customKey <= '9'
Yes, if I can read like this:
char customeKey;
if('0' <= customKey <= '9')
     Serial.println(customeKey);
Not for me
if (customKey >= '0' and <= '9')
would be better (for me)
If we are going to invent new syntax then why not
if (customKey between '0 and '9')
because i thing 0 <= x <= 9 is more mathematical
I prefer my code to be readable, almost in English if possible. The compiler can then work whatever magic it wants without bothering me
so you're suggesting 0 <= x <= 9 is less readable?
doesn't it depend on what your coding? i spent a lot of time writing code on signal processors.
Yes
Read it to me in English
if x is greater that 0 and less than 9
That is not reading it, rather it is interpreting it.
That is not the same thing at all
does "between" imply Inclusiveness?
