Clearing a global variable from within a function
I have encountered an issue which perhaps shows my naivety with respect to variable scope in c++.
I declare a global variable
uint8_t _bits[5];  // buffer to receive data
This gets filled up during execution. However, I need to clear it between loops
if I use (from within void loop())
for (uint8_t i = 0; i < 5; i++) _bits[i] = 0;
it does not seem to set all of the elements to zero?
I am not sure what I am doing wrong, do I need to use pointers??
Thanks
Martyn
This is with code tags:
  _bits[i] = 0;
Koepel:
  _bits[i] = 0;
Thanks, changed now
martynwheeler:
That looks like it should work. The problem is probably somewhere else - which is why you should always post a complete program
Also, which elements are not set to zero, and how do you know?
…R
Robin2:
...R
Sorry, my debugging was doing something wrong! Sorry for bothering...
