Hi everybody,
I'm pretty new to Arduino coding but with trail and error I hope to get somewhere
Currently I'm working on a project where I want to use an encoder to control the speed and position of a stepper motor.
The encoder has 2 functions: Either setting the speed or changing the max position of a bounce effect. I switch between the 2 states by pushing the encoder button.
Up until now everything works flawlessly except for when I press the button to change functions the value of the setting resets to 1 instead of the stored value I had before.
Does anybody have an idea on how to fix this issue?
Thank you very much.
#include <Encoder.h>
#include <FlexyStepper.h>
//Pin assignments
#define LED_PIN 10
#define NUM_LEDS 26
const int MOTOR_STEP_PIN = 12;
const int MOTOR_DIRECTION_PIN = 11;
const int LIMIT_SWITCH_PIN = 6;
const int pushbutton = 5;
Encoder g_encoder(2, 3);
//Variable Config
int menu = 0;
int state = 0;
int oldbutton = 0;
int pos;
int motpos;
int motSpeed;
int button;
//Stepper Config
FlexyStepper stepper;
volatile bool g_has_not_homed = true;
const float maxStrokeLengthMm = 200; //Max length of movement
const float minStrokeLengthMm = 20; //Min length of movement
const float StepsPerRev = 800;
//LED Config
Adafruit_NeoPixel pixels(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
pinMode(LIMIT_SWITCH_PIN, INPUT_PULLUP);
pinMode(pushbutton, INPUT_PULLUP);
//LED setup
pixels.begin();
pixels.clear();
pixels.fill(pixels.Color(0, 0, 0),0,NUM_LEDS);
pixels.show();
//Stepper setup
stepper.connectToPins(MOTOR_STEP_PIN, MOTOR_DIRECTION_PIN);
stepper.setStepsPerMillimeter(StepsPerRev / 40);
stepper.setSpeedInMillimetersPerSecond(0);
stepper.setAccelerationInMillimetersPerSecondPerSecond(200);
//Homing sequence
delay(100);
Serial.println("Homing Started");
if (g_has_not_homed == true)
pixels.fill(pixels.Color(50, 0, 25),0,NUM_LEDS);
pixels.show();
stepper.setSpeedInMillimetersPerSecond(25);
stepper.moveToHomeInMillimeters(1, 25, 300, LIMIT_SWITCH_PIN);
stepper.setSpeedInMillimetersPerSecond(100);
Serial.println("Move to Start Position");
stepper.moveToPositionInMillimeters(-minStrokeLengthMm);
stepper.setCurrentPositionInMillimeters(-minStrokeLengthMm);
g_has_not_homed = false;
pixels.fill(pixels.Color(0, 50, 0),0,NUM_LEDS);
pixels.show();
Serial.println("Ready");
//Encoder Limit setup
int encLimitRead(int minVal, int maxVal){
if(g_encoder.read()>maxVal*4)g_encoder.write(maxVal*4);
else if(g_encoder.read()<minVal*4) g_encoder.write(minVal*4);
return constrain(g_encoder.read()/4,minVal,maxVal);
pixels.clear();
button = digitalRead(pushbutton);
if (oldbutton == 0 && button == 1){
if (menu==0){
menu = 1;
Serial.println("");
Serial.println("Position Menu:");
Serial.println("");
g_encoder.write(pos);
else{
menu = 0;
Serial.println("");
Serial.println("Speed Menu:");
Serial.println("");
g_encoder.write(motSpeed);
oldbutton = button;
if (menu == 0){
long newSpeed = encLimitRead(0,NUM_LEDS);
//SPEED MENU
if (newSpeed != motSpeed) {
motSpeed = newSpeed;
pixels.fill(pixels.Color(50, 0, 0),0,motSpeed);
pixels.show();
stepper.setSpeedInMillimetersPerSecond(4*motSpeed);
Serial.print("Speed: ");
Serial.print(motSpeed);
Serial.print(" Position: ");
Serial.println(motpos);
if (motSpeed == 0){
pixels.fill(pixels.Color(0, 0, 0),0,0);
pixels.show();
} else{
long newpos = encLimitRead(0,NUM_LEDS);
//POSITION MENU
if (newpos != pos) {
motpos = map(newpos, 0, NUM_LEDS, minStrokeLengthMm, maxStrokeLengthMm);
Serial.print("Position: ");
Serial.print(motpos);
Serial.print(" Speed: ");
Serial.println(motSpeed);
pixels.fill(pixels.Color(0, 0, 50),0,newpos);
pixels.show();
pos = newpos;
if (pos == 0){
pixels.show();
if (state == 0){
stepper.setTargetPositionInMillimeters(-minStrokeLengthMm);
stepper.processMovement();
} else{
stepper.setTargetPositionInMillimeters(-(motpos));
long currentPosition = stepper.getCurrentPositionInMillimeters();
if (currentPosition == -minStrokeLengthMm){
state = 1;
if (currentPosition == -(motpos)){
state = 0;
