Hi, I am trying to run a simple automated device with a motor and a limit switch. I have most of the code working, however certain times when I am getting the state of the limit switch, it seems to read the state from when the state was previously read. Even if the button hasnt been pressed in multiple seconds and update the state using
int state = limitSwitch.getState();
here is a simple script I made that demonstrates the issue
#include <ezButton.h>
//Setup all Pin Locations
ezButton limitSwitch(7); // create ezButton object that attach to pin 7;
limitSwitch.setDebounceTime(50); // set debounce time to 50 milliseconds
while (true) {
limitSwitch.loop();
if(state == LOW){
Serial.println("The limit switch: TOUCHED");
break; // Exit loop
Serial.println("The limit switch: UNTOUCHED");
Serial.println("next loop");
once i press the button I get 2 outputs sayings its been pressed even though I would think it should only be 1
next loop
next loop
I know its probably a simple thing but I'm not that familiar with C and i havent been able to figure it out
