Cleber Oliveira
Meus caros,
Preciso utilizar 4 sensores TCS3200 em um projeto, neste caso eu irei utiliza-lo em uma placa somente do arduino Mega...
Saberão dizer se existe alguma restrição de conecta-los em uma placa somente?
Dear,
I need to use 4 TCS3200 sensors in a project, in this case I will use it on a Mega Arduino board only ...
Will they know if there are any restrictions on connecting them to a single board?
Datasheet:
you should edit the title of your thread to something like "using 4 TCS3200 sensors with 1 arduino Mega"
then describe what kind of sensor this is.
I'm a friend of think with your own head: If you look at the datasheet what do you think how many IO-oins do you need per sensor? How many IO-pins does a Arduino Mega 2560 have?
best regards Stefan
any newbee can apply the most professional habit from the first line of code they write on their own:
add only ONE thing at a time. Test/debug that ONE thing until that ONE thing works reliable - repeat.
The sad thing is: only the REAL professionals write code this way.
