This got packaged as a separate library in the hope that it may be useful to others.
Features:
"Grammar, Lexer, Interactive Terminal Command sHell"
- Terminal / command host for inclusion in Arduino and embedded projects.
- Simple definition of an arbitrary command grammar.
- Interactive command and control with basic terminal emulation.
- "Plug in" design - does not require fundamental project code changes.
- Command help generated automatically from the command grammar.
- Management of enums and associated string arrays - for use in code and the grammar.
- Helps extension and maintenance of firmware code and configuration schemas by providing a single source, "master" meta config (if such functionality is relevant to the project).
- glitch compiles the grammar and produces out.h and associated files.
- itch.h is the parser and terminal - gets included with out.h in embedded projects.
