hello
it is possible to do the Library manger and Board Manger update with command line ?
have a nice day
vinc
Yes. If you're using the Arduino IDE, you can find the documentation for the --install-boards and --install-library flags here:
You can also use Arduino CLI to do this if you want a purely command line tool:
https://arduino.github.io/arduino-cli/latest/
@pert thanks for your feedback
your links shows only to install it new - but i just wish to do the update from what i have installed in the IDE.
Or i did missunderstood the text.
have a nice day
vinc
Yes, it's possible:
--install-boards package name:platform architecture[:version]
Fetches available board support (platform) list and install the specified one, along with its related tools. If version is omitted, the latest is installed. If a platform with the same version is already installed, nothing is installed and program exits with exit code 1. If a platform with a different version is already installed, it’s replaced.--install-library library name[:version]
Fetches available libraries list and install the specified one. If version is omitted, the latest is installed. If a library with the same version is already installed, nothing is installed and program exits with exit code 1. If a library with a different version is already installed, it’s replaced. Multiple libraries can be specified, separated by a comma.
So if you wanted to update the "Arduino AVR Boards" platform of the Uno, Mega, etc., you can run this command:
arduino --install-boards arduino:avr
or on Windows:
arduino_debug --install-boards arduino:avr
It's the same with Arduino CLI:
arduino-cli core install arduino:avr
but Arduino CLI has an extra feature you might like:
https://arduino.github.io/arduino-cli/latest/commands/arduino-cli_upgrade/
Upgrades installed cores and libraries to latest version.
arduino-cli upgrade [flags]
If you run that command, it upgrades everything you have installed to the latest version!
