'cli() wasn't declared in this scope' Problem
I’m trying to run this code below and I got the
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:502:7: error: 'cli' was not declared in this scope
error
Board: Arduino Due
IDE: 1.6.7
unsigned char
#include <SoftwareSerial.h>
SoftwareSerial BT(10, 11); //TX, RX respetively
String readvoice;
 BT.begin(9600);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  while (BT.available()){  //Check if there is an available byte to read
  delay(10); //Delay added to make thing stable
  char c = BT.read(); //Conduct a serial read
  readvoice += c; //build the string- "forward", "reverse", "left" and "right"
  if (readvoice.length() > 0) {
    Serial.println(readvoice);
  if(readvoice == "forward")
    digitalWrite(3, HIGH);
    digitalWrite (4, HIGH);
    digitalWrite(5,LOW);
    digitalWrite(6,LOW);
    delay(100);
  else if(readvoice == "reverse")
    digitalWrite(3, LOW);
    digitalWrite(4, LOW);
    digitalWrite(5, HIGH);
    digitalWrite(6,HIGH);
    delay(100);
  else if (readvoice == "right")
    digitalWrite (3,HIGH);
    digitalWrite (4,LOW);
    digitalWrite (5,LOW);
    digitalWrite (6,LOW);
    delay (100);
 else if ( readvoice == "left")
   digitalWrite (3, LOW);
   digitalWrite (5, LOW);
   digitalWrite (6, LOW);
   delay (100);
 else if (readvoice == "stop")
   digitalWrite (4, LOW);
   delay (100);
readvoice="";}} //Reset the variable
Any ideas? I did see that I should use the atomic.h library, but I didn’t really understand how to do that because I’m … a newbie.
  1. You are in the wrong forum you should have posed in the Due forum.
  2. Software serial does not work of the Due 0 there may be an equivalentt but it should have a different name.
cli()/sei() are instructions for the chip (an AVR) used in the Uno/Mega. The Due uses a totally different chip!
Mark
I had no idea there was a Due forum
Then how should I go about it?
That depends entirely on what "it" is that you want to go about.
Just wait your post will be moved for you by the mod's.
In the mean tine just use interrupts() and nointerrupts()
Mark
Thanks a lot…
No need to be rude about it :confused:
By PaulS' standards, that was a particularly polite message. He really is ready and willing to help you with whatever problem you have, so long as you describe what the problem is in a little more detail.
Or any of the other regulars can help too. I believe Paul is human and does need to sleep.
ROFL
Mark
