click during loop delay
Im doing a radio project and while in the loop the delay makes an audible clicking noise from the speaker the less the delay the faster the clicking.Is there a way to fix this. The delay that makes the noise is just before the switch case .criticize welcome .I've just started with trying to code
#include <Wire.h>
#define signslInputButton 2
#define stationPotIn A0
#define VoumePotIn A2
int inputState=0;
int oldInputState=0;
int inputButtonPoll=0;
int volumeState=0;
int frequencyPLL;
int volume;
int oldVolume=0;
int volumeConverted=0;
int oldPotState;
int potState = 0;
int potStateConverted;
float station;
const int numReadings =2;
int readings[numReadings];      // the readings from the analog input
int readIndex = 0;              // the index of the current reading
int total = 0;
const int numReadings2 =2;
int readings2[numReadings2];      // the readings from the analog input
int readIndex2 = 0;              // the index of the current reading
int total2 = 0;
float stationArray[100]={88.1,88.3,88.5,88.7,88.9,89.1,89.3,89.5,89.7,89.9,
                        90.1,90.3,90.5,90.7,90.9,91.1,91.3,91.5,91.7,91.9,
                        92.1,92.3,92.5,92.7,92.9,93.1,93.3,93.5,93.7,93.9,
                        94.1,94.3,94.5,94.7,94.9,95.1,95.3,95.5,95.7,95.9,
                        96.1,96.3,96.5,96.7,96.9,97.1,97.3,97.5,97.7,97.9,
                        98.1,98.3,98.5,98.7,98.9,99.1,99.3,99.5,99.7,99.9,
                        100.1,100.3,100.5,100.7,100.9,101.1,101.3,101.5,101.7,101.9,
                        102.1,102.3,102.5,102.7,102.9,103.1,103.3,103.5,103.7,103.9,
                        104.1,104.3,104.5,104.7,104.9,105.1,105.3,105.5,105.7,105.9,
                        106.1,106.3,106.5,106.7,106.9,107.1,107.3,107.5,107.7,107.9};
int volumeArray[40]={0x60,/*0x5f,*/0x5e,/*0x5d,*/0x5c,/*0x5b,*/0x5a,/*0x59,*/0x58,/*0x57,*/0x56,/*0x55,*/0x54,/*0x53,*/0x52,/*0x51,*/0x50,
                     /*0x4f,*/0x4e,/*0x4d,*/0x4c,/*0x4b,*/0x4a,/*0x49,*/0x48,/*0x47,*/0x46,/*0x45,*/0x44,/*0x43,*/0x42,/*0x41,*/0x40,
                     /*0x3f,*/0x3e,/*0x3d,*/0x3c,/*0x3b,*/0x3a,/*0x39,*/0x38,/*0x37,*/0x36,/*0x35,*/0x34,/*0x33,*/0x32,/*0x31,*/0x30,
                     /*0x2f,*/0x2e,/*0x2d,*/0x2c,/*0x2b,*/0x2a,/*0x29,*/0x28,/*0x27,*/0x26,/*0x25,*/0x24,/*0x23,*/0x22,/*0x21,*/0x20,
                     /*0x1f,*/0x1e,/*0x1d,*/0x1c,/*0x1b,*/0x1a,/*0x19,*/0x18,/*0x17,*/0x16,/*,0x15,*/0x14,/*,0x13,*/0x12/*,0x11,0x10,
                     0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f*/};
    pinMode(VoumePotIn,INPUT);
    pinMode(stationPotIn,INPUT);
    pinMode(signslInputButton,INPUT_PULLUP);
    Wire.begin();
    Serial.begin (9600);
    Wire.beginTransmission( 0x44 );
    Wire.write( 0x20 );                 // deault settings to get audio ic started
    Wire.write( 0x78 );
    Wire.write( 0x00 );
    Wire.write( 0x81 );
    Wire.write( 0x60 );
    Wire.write( 0xff );
    Wire.write( 0x00 );
    Wire.write( 0x1f );
    Wire.write( 0x10 );
    Wire.write( 0x00 );
    Wire.write( 0x07 );
    Wire.write( 0x05 );
    Wire.write( 0x05 );
    Wire.write( 0x05 );
    Wire.write( 0x05 );
    Wire.write( 0x8f );
    Wire.write( 0x05 );
    Wire.write( 0xdf );
    Wire.write( 0x00 );
    Wire.endTransmission();
   // used for smoothing volume pot input
    for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0;
  // used for smoothing station pot input
    for (int thisReading2 = 0; thisReading2 < numReadings2; thisReading2++) {
    readings2[thisReading2] = 0;
void loop(){
  total = total - readings[readIndex];              // subtract the last reading:
  readings[readIndex] = analogRead(VoumePotIn);      // read from the pot:
  total = total + readings[readIndex];               // add the reading to the total:
  readIndex = readIndex + 1;                         // advance to the next position in the array:
 if (readIndex >= numReadings) {                     // ...wrap around to the beginning:
    readIndex = 0;
   // calculate the average:
   volumeState = total / numReadings;
   // delay in between reads for stability
   delay(1);
    // dont write unless pot has rotated
    if(abs(volumeState-oldVolume)>9){
        oldVolume=volumeState;
        volumeConverted=map(volumeState,0,1023,0,39);
        volume=volumeArray[volumeConverted];
        Wire.write( 0x03 );
        Wire.write( volume );
        Serial.println(volume);
  total2 = total2 - readings2[readIndex2];                    // subtract the last reading:
  readings2[readIndex2] = analogRead(stationPotIn);           // read from the pot:
  total2 = total2 + readings2[readIndex2];                     // add the reading to the total:
  readIndex2 = readIndex2 + 1;                                 // advance to the next position in the array:
  if (readIndex2 >= numReadings2) {                             // if we're at the end of the array...
      readIndex2 = 0;                                           // ...wrap around to the beginning:
  potState = total2 / numReadings2;
  delay(1);
  if(abs(potState-oldPotState)>5){
        oldPotState=potState;
        potStateConverted=map(potState,0,1023,0,100);
        station=stationArray[potStateConverted];
        frequencyPLL = 4 * ( station * 1000000 + 225000 ) / 32768 ;
   //data sheet for FM ic said add this delay
    delay(100);
   //write radio station to fm radio ic
    Wire.beginTransmission( 0x60 );
    Wire.write( highByte(frequencyPLL) );
    Wire.write( lowByte(frequencyPLL) );
    Wire.write( 0xB0 );
    Wire.write( 0x17 );
    Wire.write( 0x00 );
    Serial.println(station);
    //select FM/AUX/BLUETOOTH and remember selection
    //  and debounce button
    inputButtonPoll=digitalRead(signslInputButton);
    if(inputButtonPoll == 0){
      delay(50);
      if(inputButtonPoll == 1){
        inputState = oldInputState +1 ;
        Serial.println(inputState);
//if button has not been pressed wait 100ms
    else{
      delay(50);
    switch (inputState) {
      case 1:
      // program audio ic for AUX input
        Wire.write( 0x00);
        Wire.write( 0x78 );
      // remember selection
        oldInputState = inputState;
      case 2:
      // program audio ic for FM input
        Wire.write( 0x00 );
        Wire.write( 0x79 );
      case 3:
      //program audio ic for Bluetooth input
        Wire.write( 0x00 );
        Wire.write( 0x7b );
        oldInputState = 0;
I would start by not posting any code.
Oh, look! You're off to a good start.
Look at line 59.
unfortunately it looks like no help on this one either .
What are the big delays in the code for? I don't understand their purpose.
Hard to say exactly what is going on. The few comments you do have are for fairly obvious things, such as:
But there aren't any comments on more obscure lines like:
        Wire.write( 0x00 );
        Wire.write( 0x79 );
Then there are the incorrect comments:
volumeState = total / numReadings;                   // send it to the computer as ASCII digits  - not sending anything
Usually, clicking is caused by the loss of part of the signal caused by overflow of the buffer.
ive edited with more comments
it doesn't have clicking sound if i omit this part of code
      delay(50);
    else{
      delay(50);
      case 1:
        Wire.write( 0x00);
        Wire.write( 0x78 );
      case 2:
        Wire.write( 0x00 );
        Wire.write( 0x79 );
      case 3:
        Wire.write( 0x00 );
        Wire.write( 0x7b );
        oldInputState = 0;
I fixed it .I removed the else statement and no more clicking.I changed this
      delay(50);
    else{
      delay(50);
      case 1:
        Wire.write( 0x00);
        Wire.write( 0x78 );
      case 2:
        Wire.write( 0x00 );
        Wire.write( 0x79 );
      case 3:
        Wire.write( 0x00 );
        Wire.write( 0x7b );
        oldInputState = 0;
to this
      delay(50);
      case 1:
        Wire.write( 0x00);
        Wire.write( 0x78 );
      case 2:
        Wire.write( 0x00 );
        Wire.write( 0x79 );
      case 3:
        Wire.write( 0x00 );
        Wire.write( 0x7b );
        oldInputState = 0;
