Clickbutton Delay
I am tinkering on clickbutton library.(https://code.google.com/p/clickbutton/) In the usage page,it says to avoid using delay because of interrupts.So it has to be delay without "delay".I have tried some but it doesn't work.Can you check it?
#include "ClickButton.h"
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;           // interval at which to blink (milliseconds)
const int buttonPin1 = 4;
ClickButton button1(buttonPin1, LOW, CLICKBTN_PULLUP);
int LEDfunction = 0;
void delay8(){
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // set the LED with the ledState of the variable:
    digitalWrite(8, LOW);
  pinMode(8,OUTPUT);
  // Setup button timers (all in milliseconds / ms)
  // (These are default if not set, but changeable for convenience)
  button1.debounceTime   = 20;   // Debounce timer in ms
  button1.multiclickTime = 250;  // Time limit for multi clicks
  button1.longClickTime  = 1000; // time until "held-down clicks" register
  // Update button state
  button1.Update();
  // Save click codes in LEDfunction, as click codes are reset at next Update()
  if (button1.clicks != 0) LEDfunction = button1.clicks;
  // Simply toggle LED on single clicks
  // (Cant use LEDfunction like the others here,
  //  as it would toggle on and off all the time)
  if(LEDfunction == 2)  {
    digitalWrite (8,HIGH);
    delay8();
    digitalWrite (8,LOW);
When you enter a double click the LED will go ON, then after a time out period it will go OFF,
however, since LEDfunction == 2 will still be true the LED will immediately turn back ON in the next loop.
This repeats over and over as long as LEDfunction == 2 is ture.
Your eye never sees the LED go off since things happen so fast. If you had a logic probe you would see it pulse on pin 8. Put at Serial.print after previousMillis = currentMillis and you will see it executed. OR you can but a delay(100); after the write low to stop the code for a while and you will see the led will go out.
After the delay8() in loop() why are you doing a digitalWrite, isn't that the job of your function?
You should get into the habit of always using unsigned long for variables that have something to with
millis() example: instead of long previousMillis = 0; use unsigned long previousMillis = 0;
Also IMO long interval = 1000; should be const unsigned long interval = 1000UL;
    delay8();
"digitalWrite (8,LOW);"This line is unnecessary.My mistake.
    digitalWrite(13, LOW);
    delay(100);
Yes the led blinks.I understood the problem.How to solve it?Reset the ledfunction function?or buttonupdate after delay8 function?or any other solution?
Two things you have to do:
A. You have to clear the value of LEDfunction once there is a time out in delay8().
B. Then add the line:
previousMillis = millis(); <<<<<< add this line so there is an initialized value once there is a new detection
EDIT:
Some advice, clean up your code a bit as it is hard to look at, remove some blank lines.
Place { on a new line.
I always use { and } in if statements rather than including code on the same line as the if(......)
Use Ctrl t to format your code into a more readable sketch.
I have added this code according to your last post and it works fine.
void delay8(){
    LEDfunction = 0;
Thank you.
Great!
I assume you follow the logic.
Thanks for reporting back.
