Greetings,
some time ago good people from this forum helped me come up with a program for my problem that i had...In short, the idea of the program is to have 10 sensors and 10 LED's. So the first question in the code below is...how do i simply add 5 more sensors with their corresponding LED's to light up respectively, blink a few times and then turn back off, just like the first 5 sensors and LED's that are already in the program. Except, when the first 5 LED's are all lit up and they do the blink, a MARIO sound effect is triggered. But for the other 5 LED's, i would somehow like to add a different sound effect to happen [e.g. coin effect]? The sound effects for each individual sensors should play too.
Next problem is i started getting a clicking sound from the buzzer at any given moment the program is runing. I think this represents that a delay function or something must constantly keep restarting a sound effect, but i cannot seem to find the problem..If someone could have a look a the program, fix anything or try to help i will be very gratefull..Keep in mind that i have a very hard time learning C and i dont always understand the code...Thank you in advance!!
BASED ON State change detection (edge detection) changed for INPUT PULLUP
and with a struct array
delay()-less millis()-based pulse pin 13
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define SD_ChipSelectPin 53 //example uses hardware SS pin 53 on Mega2560
TMRpcm audio; // create an object for use in this sketch
File myFile;
char line[25];
byte index = 0;
// the buttons
struct buttons
byte pin;
byte led;
bool state;
bool prevState;
byte score;
byte pressed;
char muzika[10];//tu dodam string ki bo vseboval ime datoteke z muziko/////lahko se znajša na manj znakov/////////////////////////////////////////////////////////////
const byte buttonPins[] = {13, 14, 15, 16 , 17}; //Senz za M A R I O
const byte numberOfButtons = sizeof(buttonPins) / sizeof(buttonPins[0]);
buttons mybuttons[numberOfButtons];
const byte ledPins[] = {23, 24, 25, 26, 27};
const byte scores[] = {10, 20, 30, 40, 50};
const char *ImenaMuzik[] ={"boo.wav","coin.wav","opica.wav","boomba.wav","shyguy.wav",};//tu dodam polje stringov ki vsebujejo imena datotek z muziko////////preimenuj v imena datotek/////////////////////////////////////////////////////////
///END SENSOR CONF
bool reading;
const int button = 49;
bool prevState;
//SCORING
long highscore = 0;
long runningTotal;
byte numberOfButtonsPressed = 0;
//the effect led
int effectLedInterval;
int effectLedIntervalMax = 100;
int effectLedIntervalMin = 30;
unsigned long previousMillisEffect;
bool effectState;
bool doEffect = false;
unsigned long before = 0;
const long interval = 100;
// initialize serial communication:
Serial.println("setup() ... ");
Serial.println("** 679079 **");
Serial.print("Compiler: ");
Serial.print(__VERSION__);
Serial.print(", Arduino IDE: ");
Serial.println(ARDUINO);
Serial.print("Created: ");
Serial.print(__TIME__);
Serial.print(", ");
Serial.println(__DATE__);
Serial.println(__FILE__);
// initialize the button pins as input with pullup so active low
// make sure the button is from pin to ground
Serial.println(" ");
Serial.print("Initialising "); Serial.print(numberOfButtons); Serial.println(" buttons");
for (int i = 0; i < numberOfButtons; i++)
mybuttons[i].pin = buttonPins[i];
pinMode(mybuttons[i].pin, INPUT_PULLUP);
mybuttons[i].led = ledPins[i];
pinMode(mybuttons[i].led, OUTPUT);
mybuttons[i].state = digitalRead(mybuttons[i].pin);
mybuttons[i].prevState = mybuttons[i].state;
mybuttons[i].score = scores[i];
mybuttons[i].pressed = 0;
Serial.print("Button: "); Serial.print(i);
Serial.print(", Pin: "); Serial.print(mybuttons[i].pin);
Serial.print(", Led: "); Serial.print(mybuttons[i].led);
Serial.print(", Score: "); Serial.print(mybuttons[i].score);
Serial.print(", Pressed: "); Serial.print(mybuttons[i].pressed);
Serial.print(", State: "); Serial.print(mybuttons[i].state);
Serial.print(", Prev state: "); Serial.println(mybuttons[i].prevState);
strcpy(mybuttons[i].muzika, ImenaMuzik[i]);//tu vstavim ime muzike v spremenljivko za ta button////////////////////////////////////////////////////////////////////
Serial.println("setup() done");
Serial.println("Press a button....");
pinMode(49, INPUT_PULLUP);
audio.speakerPin = 11; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
audio.setVolume(5);
if (!SD.begin(SD_ChipSelectPin)) {
return;
Serial.println("SD OK");
//Write high score to LCD on startup
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
line[index] = (myFile.read());
// check if character is '\r'
if (line[index] == '\r')
// add terminatin NUL character
line[index] == '\0';
// done
// next character will go in next element of line
index++;
// close the file:
highscore = atol(line);
myFile.close();
checkForButtonStateChange();
if (doEffect) blinkLedsAndMakeANoise();
checkIfStopWasPressed();
text();
} //loop
void checkForButtonStateChange()
// compare the buttonState to its previous state
if (mybuttons[i].state != mybuttons[i].prevState) // means it changed... but which way?
if (mybuttons[i].state == HIGH) // changed to pressed
if(audio.isPlaying()==0){ //returns 1 if music playing, 0 if not
audio.play(mybuttons[i].muzika);//plays effect for specific button/////////////////////////////////////////////////////////////////////////////
Serial.print(i);
Serial.print(" newly pressed");
if (mybuttons[i].pressed == 0)
mybuttons[i].pressed = 1;
numberOfButtonsPressed++;
Serial.print(", Unique buttons pressed "); Serial.print(numberOfButtonsPressed);
digitalWrite(mybuttons[i].led, HIGH);
runningTotal = runningTotal + mybuttons[i].score;
Serial.print(", Score "); Serial.println(runningTotal);
// poor man's de-bounce
delay(50);
// save the current state as the last state, for next time through the loop
if (numberOfButtonsPressed == 5)
Serial.print("All leds on, score "); Serial.println(runningTotal);
audio.play("mario.wav");
doEffect = true;
} // checkForButtonStateChange()
void blinkLedsAndMakeANoise()
static byte numberOfEffects = 0;
if (millis() - previousMillisEffect >= effectLedInterval)
effectLedInterval = random(effectLedIntervalMin, effectLedIntervalMax);
previousMillisEffect = millis();
effectState = !effectState;
digitalWrite(mybuttons[i].led, effectState);
numberOfEffects++;
if (numberOfEffects == 25)
doEffect = false;
digitalWrite(mybuttons[i].led, LOW);
void checkIfStopWasPressed()
reading = digitalRead(49);
if (reading == 0) { //button was pressed
delay(50);
if (runningTotal > highscore) { //check if current score > highsore
highscore = runningTotal; //if current score> highscore, write that score to SD card
SD.remove("test.txt"); //izbriše file z starim rezultatom, ustvari nov file z novim high score-om.
delay(50);
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println(highscore);
myFile.close();
void text() {
if (millis() - before >= interval) {
before = millis();
lcd.clear();
lcd.setCursor(4, 0);
lcd.print(runningTotal);
lcd.setCursor(4, 1);
lcd.print(highscore);
