I am attempting to create a device that will use a servo to push the left hand mouse button. The actual armature that holds the mouse and the servo in position has been created, but I am having issues with the code. The code needs to do the following:
-Move servo to 45 degrees and then return to 0 at a random amount of time between 5-10Ms
-wait 1.55 to 1.65 seconds before starting again
-print the random times generated for each variable time.
I am really just starting out and don't know much about coding so any advice or help is appreciated.
Arduino boards based on the 32u4 can emulate a HID device, and thus act like a mouse when plugged into USB. The due can too, but it's a more advanced board. See http://arduino.cc/en/Reference/MouseKeyboard
Wouldn't that be a better way to achieve your goal?
Alternately, what about putting a relay across the switch on the LMB?
Using a servo for this seems... a bit ridiculous... unless you're doing it for show.
You can plug in multiple USB mice with no problems (except for 2-year-olds).
Use a screwdriver - hack one, you will generally find a microswitch which switches to ground.
Attach an NPN transistor across microswitch or even better - an opto-coupler. Control it (using a suitable resistor - 220 ohms for opto, 10k for transistor) with an Arduino port.
