client.connect(mac, ip) fails and returns 0
Hello Guys
I work on a project where I meassure the temperature and then send it to a webserver with my arduino.
I tried this whole setup with a arduino uno and a w5100 ethernetshiel where it worked perfect.
Now I want to get a bit more professionall and smaller so I decided to use a arduino nano and a mini enc28j60. Now I am at a point where I don't know my mistake. I saw that the connections depend on the libraries you use. I treid it with pin 8 and ethercard.h and now I am at pin 10 and UIPEthernet.h.
I think the problem is either at the connections or at the code/library.
I attached a picture of the plan how i connected everything.
And here's my code:
#include <UIPEthernet.h>
  EthernetClient client;
  IPAddress ip(192, 168, 0, 243);
byte mac[] = { 0x54, 0x34, 0x41, 0x30, 0x31, 0x31 };
// MAC in decimal{ 84, 52, 65, 48, 49, 49 };
  char server[] = "192.168.0.184";
  IPAddress dnsserver(192, 168, 0, 8);
  Ethernet.begin(mac, ip, dnsserver);
while(!Serial)
  Serial.print("IP Address        : ");
  Serial.println(Ethernet.localIP());
  Serial.print("Subnet Mask       : ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("Default Gateway IP: ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("DNS Server IP     : ");
  Serial.println(Ethernet.dnsServerIP());
  int x = client.connect(server, 80);
  if (x == 1) {
    Serial.println("-> Connected");
    client.print( "GET /add.php?");
    client.print("temp=");
    client.print( "12.3" );
    client.println( " HTTP/1.1");
    client.print( "Host: " );
    client.println(server);
    client.println( "Connection: close" );
    client.println();
    client.println();
    client.stop();
    Serial.println("Data sent. Waiting a bit to reconnect.");
  else {
    Serial.print("--> connection failed: ");
    Serial.println(x);
And if I just try to get the IP and so on by SHCP all I get is 0.0.0.0
Thank you for reading.
