This program worked fine for me but after a week, trying to check again, the program seems to stop at
//API service using WiFi Client through PushingBox then relayed to Google
if (client.connect(WEBSITE, 80)) {
I changed nothing (as far I can remember). Does anybody has an idea why the program is not passing this instruction?
Kind regards Peter
#include <WiFiNINA.h>
#include <DHT.h>
#include <ArduinoBLE.h>
DHT Stock = DHT(1,DHT11);
float humidityData;
float celData;
const char WEBSITE[] = "api.pushingbox.com"; //pushingbox API server
const String devid = "id"; //device ID on Pushingbox for our Scenario
char ssid[] = "said"; // your network SSID (name)
char pass[] = "pass"; // your network password
int status = WL_IDLE_STATUS;
while (!Serial);
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("You're connected to the network");
printWifiStatus();
//DHTs initialisieren
Stock.begin();
// begin initialization
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
delay(2000);
// Messung Stockklima
humidityData = Stock.readHumidity();
celData = Stock.readTemperature();
// Wenn fehlerhafte Sensordaten Meldung ausgeben
if (isnan(humidityData) || isnan(celData)) {
Serial.println("Fehler Sensor Stock!");
return;
// Ausgabe auf seriellen Monitor
Serial.print("Stockklima: ");
Serial.print("Feuchte: ");
Serial.print(humidityData);
Serial.print("% Temperatur: ");
Serial.print(celData);
Serial.println("°C");
Serial.println("\nSending Data to Server...");
// if you get a connection, report back via serial:
WiFiClient client; //Instantiate WiFi object, can scope from here or Globally
client.print("GET /pushingbox?devid=" + devid
+ "&humidityData=" + (String) humidityData
+ "&celData=" + (String) celData);
// HTTP 1.1 provides a persistent connection, allowing batched requests
// or pipelined to an output buffer
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(WEBSITE);
// client.println("User-Agent: MKR1000/1.0");
client.println();
Serial.println("\nData Sent");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
