I have the following sketches, and for some reason the client is not connecting to the server. With char[] server = "google.com";, a connection establishes but not when using the IP address of the Arduino local server, which prints in the server sketch. The client is an Sparkfun Pro Micro ESP32 and the server is an Arduino Giga. Any guidance would be greatly appreciated.
Client:
#include <Wire.h>
#include "SparkFun_STTS22H.h"
#include <SPI.h>
#include <WiFi.h>
SparkFun_STTS22H mySTTS;
float temp;
char ssid[] = "";
char password[] = "";
int status = WL_IDLE_STATUS;
WiFiClient client;
char server[] = "";
delay(5000);
Wire.begin();
if(!mySTTS.begin()) {
Serial.println("Did not begin.");
while(1);
mySTTS.setDataRate(STTS22H_POWER_DOWN);
delay(10);
mySTTS.setDataRate(STTS22H_1Hz);
mySTTS.enableAutoIncrement();
delay(100);
Serial.println("Attempting to connect to WPA network...");
Serial.print("SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, password);
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
delay(3000);
status = WiFi.status();
Serial.println("Connected to wifi");
printWifiStatus();
if(mySTTS.dataReady()) {
mySTTS.getTemperatureF(&temp);
Serial.println(temp);
if (client.connect(server, 80)) {
Serial.println("connected");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Server:
#include "Arduino_GigaDisplay_GFX.h"
#include <Wire.h>
#include <WiFi.h>
#include <math.h>
GigaDisplay_GFX display;
#define BLUE 0x0000ff
#define WHITE 0xffffff
#define BLACK 0x0000
float temp;
String insideTempOutput;
const char* ssid = "";
const char* password = "";
WiFiServer server(80);
while (!Serial);
display.begin();
display.setRotation(1);
display.fillScreen(BLACK);
display.setTextSize(8);
drawLabels();
Wire.begin();
while(1);
delay(10);
delay(100);
delay(3000);
Serial.println(ip);
void drawLabels() {
display.setTextColor(WHITE);
display.setCursor(50, 100);
display.print("Inside:");
WiFiClient client = server.available();
if (client) {
Serial.println("new client");
insideTempOutput = String((int) round(temp)) + " F";
display.setCursor(450, 100);
display.print(insideTempOutput);
delay(5000);
drawLabels();
