Client.print
Hello,
I have a problem with a program i´m doing
I want to show a value in a variable by the client.print.
When i put :
//Printing the Temperature
client.print("\n");
client.print("
client.print(sensor_1); Says that sensor_1 is anbiguos
client.print(“Temperatura”);
client.print("
\n");
client.print("");
client.print("");
client.print("
//client.print(tempOutValue);
client.print(" °C
\n");
client.print("");
client.print("");
What is the problem?
In serial.prints works
The first problem is that you have not posted your whole program. The second is that you did not use code tags as described in read this before posting a programming question
And you didn't post the actual error message. It doesn't say that sensor_1 is ambiguous. That's not a real error message. The real message says a lot more than that.
