Client.Println Ethernet Problem
Hey Everyone new to the arduino still because I do not use it at all but picked up the Ethernet shield to play with have been having fun with it but have run into a problem... My code times out so i can never get to it from a web browser if I use simple html like 2 lines it works but anything more just times out...
Please let me know what you think is wrong
http://pastebin.com/d59ee6c5d
// Define Libraries required
#include <Ethernet.h>
#include <WString.h>        // TextString Library
#include <Wire.h>
#include <BlinkM_funcs.h>    // BlinkM Library
#define blinkm_addr 0x00    // Set BlinkM Address here
// Setup for Web Server Mac, IP, Gateway, Subnet, and Port
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Mac Address needs to be Unique
byte ip[] = { 192, 168, 6, 177 };                    // IP Address
byte gateway[] = { 192, 168, 6, 1 };                 // Gateway
byte subnet[] = { 255, 255, 255, 0 };                // Subnet
char c;
String inString = String(255);                       //Sting Length of URL
Server server(80);                                   // Set Webserver Port
  //Gets the Server running with Setting set above
  Ethernet.begin(mac, ip, gateway, subnet);    // Setup Ethernet Connection
  server.begin();                              // Start Server
  BlinkM_beginWithPower();                     // Setup BlinkM
  BlinkM_stopScript( blinkm_addr );            // Set BlinkM Definition
// Converts Hex to RGB (a really cheap strtol(s,NULL,16))
#include <ctype.h>
uint8_t toHex(char hi, char lo)
  uint8_t b;
  hi = toupper(hi);
  if( isxdigit(hi) ) {
    if( hi > '9' ) hi -= 7;      // software offset for A-F
    hi -= 0x30;                  // subtract ASCII offset
    b = hi<<4;
    lo = toupper(lo);
    if( isxdigit(lo) ) {
      if( lo > '9' ) lo -= 7;  // software offset for A-F
      lo -= 0x30;              // subtract ASCII offset
      b = b + lo;
      return b;
  return 0;
  Client client = server.available();
  if (client) {
    boolean current_line_is_blank = true;      // an http request ends with a blank line
    inString = "";
    while (client.connected()) {
      if (client.available()) {
        // read the first 25 characters from the URL
        for(int z = 0; z < 25; z++)
              c = client.read();
              inString.append(c);
        int PosOfE = inString.indexOf("=");                         // Now find where our = begins
        String hexColor = String(6);                                // Now Read The 6 Characters
        hexColor = inString.substring((PosOfE + 7), (PosOfE + 1));  //Find The Hex Color Code
        int red = toHex(hexColor[0], hexColor[1]);                  // Find Color code for Red:    ??0000
        int green = toHex(hexColor[2], hexColor[3]);                // Find Color code for Green:  00??00
        int blue = toHex(hexColor[4], hexColor[5]);                 // Find Color code for Blue:   0000??
        BlinkM_fadeToRGB( blinkm_addr, red, green, blue );          // Set the Color to the BlinkM
        // if we've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so we can send a reply
          client.println("HTTP/1.1 200 OK");               // send a standard http response header
          client.println("Content-Type: text/html");       // Content is HTML
          client.println();
          // Start of Custom HTML Code
          client.println("<head><script src='http://techiscool.com/js/cp/script.js' type=text/javascript></script><title>Arduino Blinkm Color Picker</title></head>");
          client.println("<body><center>
<table style='padding: 25px 20px 0px 16px; border:1px solid #000; background-color:96919F'><tr><td>");
          client.println("<form action='index.html' method='get'>");
          client.println("<input name='MyColor' id='MyColor' class='color' value='' />");
          client.println("<input type='submit' value='Change Color' style='font-size:2em; width:12em' />");
          client.println("</form></td></tr></table>
</center>");
          client.println("<script type='text/javascript'>");
          client.println("var hex = location.search.split('=');");
          client.println("document.getElementById('MyColor').value = hex[1];");
          client.println("document.bgColor = hex[1];");
          client.println("</script></body>");
          //End of Custom HTML Code
        if (c == '\n') {
          // we're starting a new line
          current_line_is_blank = false;
        } else if (c != '\r') {
          // we've gotten a character on the current line
    // give the web browser time to receive the data
    delay(1);        // How long we wait for the Browser to Download the HTML
      client.stop(); // Finished with Everything
Thank everyone for you time
Your while doesn't really care if the client is connected or if something is available - You're better off replacing:
with
while (client.available()<25) {
...if all you are concerned with is pulling the HTTP request out. With the second code bit, I make sure that I have all 25 characters of the GET available, otherwise it gets into an endless loop.
Also, you may also want to wrap your "html" data in a html tag for your browser to render it as HTML:
 client.println("<html><head><script ..."
and close it off at the end, too.
client.println("</script></body></html>");
Thank for the Reply but all it does it time out even after the modifications you suggested
Have you been able to run the other ethernet example sketches?
And, can you try this code - it appears to also do what you are doing:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238498454
