client.publish error
hi,
i received the following error massage when trying to compile me sketch:
/home/pi/Arduino/sketch_dec24a/sketch_dec24a.ino: In function 'void loop()':
sketch_dec24a:164:47: error: invalid conversion from 'int' to 'const char*' [-fpermissive]
client.publish("Master/pH/pH1",Value_D7 );
In file included from /home/pi/Arduino/sketch_dec24a/sketch_dec24a.ino:17:0:
/home/pi/Downloads/arduino-1.8.13/libraries/pubsubclient/src/PubSubClient.h:151:12: error: initializing argument 2 of 'boolean PubSubClient::publish(const char*, const char*)' [-fpermissive]
boolean publish(const char* topic, const char* payload);
exit status 1
my code is:
[ltr]// Loading the ESP8266WiFi library and the PubSubClient library
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// Change the credentials below, so your ESP8266 connects to your router
const char* ssid = "Gjkblk-WgM";
const char* password = "FD#%G@@00";
// Change the variable to your Raspberry Pi IP address, so it connects to your MQTT broker
const char* mqtt_server = "192.168.0.72";
// Initializes the espClient
WiFiClient espClient;
PubSubClient client(espClient);
// Connect an LED to each GPIO of your ESP8266
const int pump1_Gpio2 = 2;
const int pump2_Gpio5 = 5;
 int Value_D7;
 int Value_D8;
const int Pin_D7 = 13;
int Pin_D8 = 15;
// Don't change the function below. This functions connects your ESP8266 to your router
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.print("WiFi connected - ESP IP address: ");
// This functions is executed when some device publishes a message to a topic that your ESP8266 is subscribed to
// Change the function below to add logic to your program, so when a device publishes a message to a topic that
// your ESP8266 is subscribed you can actually do something
void callback(String topic, byte* message, unsigned int length) {
  Serial.print("Message arrived on topic: ");
  Serial.print(topic);
  Serial.print(". Message: ");
  String messageTemp;
  for (int i = 0; i < length; i++) {
    Serial.print((char)message[i]);
    messageTemp += (char)message[i];
  // Feel free to add more if statements to control more GPIOs with MQTT
  // If a message is received on the topic home/office/esp1/gpio2, you check if the message is either 1 or 0. Turns the ESP GPIO according to the message
  if(topic=="Master/pumps/Pump1"){
      Serial.print("Changing GPIO 2 to ");
      if(messageTemp == "1"){
        digitalWrite(pump1_Gpio2, HIGH);
        Serial.print("On");
      else if(messageTemp == "0"){
        digitalWrite(pump1_Gpio2, LOW);
        Serial.print("Off");
  if(topic=="Master/pumps/Pump2"){
      Serial.print("Changing GPIO 5 to ");
        digitalWrite(pump2_Gpio5, HIGH);
        Serial.print("On");
        digitalWrite(pump2_Gpio5, LOW);
// This functions reconnects your ESP8266 to your MQTT broker
// Change the function below if you want to subscribe to more topics with your ESP8266
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // Subscribe or resubscribe to a topic
      // You can subscribe to more topics (to control more LEDs in this example)
      client.subscribe("Master/pumps/Pump1");
      client.subscribe("Master/pumps/Pump2");
      client.subscribe("Master/pH/pH1");
      client.subscribe("Master/pH/pH2");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
// The setup function sets your ESP GPIOs to Outputs, starts the serial communication at a baud rate of 115200
// Sets your mqtt broker and sets the callback function
// The callback function is what receives messages and actually controls the LEDs
  //  PH 1,2
  Serial.begin(9600);   //Start serial monitor
  pinMode(Pin_D7,OUTPUT);
  pinMode(Pin_D8,OUTPUT);
  pinMode(A0,INPUT);
  // End PH 1,2
  pinMode(pump1_Gpio2, OUTPUT);
  pinMode(pump2_Gpio5, OUTPUT);
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
// For this project, you don't need to change anything in the loop function.
// Basically it ensures that you ESP is connected to your broker
//       PH
digitalWrite(Pin_D7, HIGH);     //Turn D7 On
  delay(1000);                     //Wait for sensor
  Value_D7 = analogRead(0);    //Read Analog pin as D7
  digitalWrite(Pin_D7, LOW);      //Turn D7 Off
  //Repeat for D8
  digitalWrite(Pin_D8, HIGH);     //Turn D8 On
  Value_D8 = analogRead(0);       //Read Analog pin as D8
  digitalWrite(Pin_D8, LOW);      //Turn D8 Off
  //Print the results to the serial monitor
  Serial.print("D7 = ");
  Serial.print(Value_D7);
  Serial.print(" / D8 = ");
  Serial.println(Value_D8);
 // End PH
  if (!client.connected()) {
    reconnect();
  client.loop();
[/ltr]
The line that causes the error
The publish() function in the PubSubClient library has several overloaded versions
   boolean publish(const char* topic, const char* payload, boolean retained);
   boolean publish(const char* topic, const uint8_t * payload, unsigned int plength);
   boolean publish(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
   boolean publish_P(const char* topic, const char* payload, boolean retained);
   boolean publish_P(const char* topic, const uint8_t * payload, unsigned int plength, boolean retained);
None of them take an int as the second of 2 parameters, hence the error message
Convert the value of Value_D7 to a string using the itoa() function and send that
Thank you for replaying,
however, after many tries still could not make it to work.
Can you please write me the correct syntax for publishing Value_D7 to "Master/pH/pH1"
thank you
