Hello everyone,
I'm trying to connect two Arduinos R4 via Wifi. The main Board should trigger the sub to turn on/off it's LED (in the long run, it should trigger several LEDs on several boards, but one step at a time). Unfortunately I fail to get the response back, so the main Board, can't decide, if turn on or off.
Code for the Main:
#include <WiFi.h>
//Choose which LED on own or remote Boards to turn on
const char* ssid = "test_wifi"; // Replace with your WiFi SSID
const char* password = "Test_wifi_password_12"; // Replace with your WiFi password
const char* serverIP = "192.168.178.152"; // Static IP address of Arduino 1 (Server)
const int serverPort = 80; // Port the server is listening on
IPAddress localIP(192, 168, 178, 151); // Set static IP address (use any available IP in your network range)
IPAddress gateway(192, 168, 1, 1); // Set gateway address (usually your router IP)
IPAddress subnet(255, 255, 255, 0); // Set subnet mask
int status = WL_IDLE_STATUS;
WiFiClient client;
// Connect to WiFi
WiFi.config(IPAddress(localIP));
// print the network name (SSID);
Serial.print("Creating access point named: ");
Serial.println(ssid);
// Create open network. Change this line if you want to create an WEP network:
status = WiFi.beginAP(ssid, password);
if (status != WL_AP_LISTENING) {
Serial.println("Creating access point failed");
// don't continue
while (true);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to WiFi");
// Request the current LED status
if (client.connect(serverIP, serverPort)) {
delay(100);
Serial.println("Connected to server");
// Send the request to get the LED status
client.println("LED_STATUS");
// Wait for and print the server's response
String response = client.readStringUntil('\n'); // Use '\n' to match the server's end of line
if (response.length() > 0) {
Serial.print("Server Response: ");
Serial.println(response); // Print out the response from the server
Serial.println("No response from server or empty response");
// Parse the response to check the current LED status
if (response.indexOf("LED Status: ON") != -1) {
Serial.println("LED is ON, requesting to turn it OFF");
toggleLED("OFF"); // If the LED is ON, request to turn it OFF
} else if (response.indexOf("LED Status: OFF") != -1) {
Serial.println("LED is OFF, requesting to turn it ON");
toggleLED("ON"); // If the LED is OFF, request to turn it ON
client.stop(); // Disconnect from the server
Serial.println("Disconnected from server");
delay(10000); // Wait for 5 seconds before sending the next request
Serial.println("Connection to server failed");
delay(1000); // Retry after 1 second
void toggleLED(const String& status) {
// Send the request to toggle the LED
client.println("TOGGLE_LED");
String response = "";
while (client.available()) {
response += client.readString();
Serial.println("Server Response to toggle:");
Serial.println("Failed to send toggle command");
Code for the sub
#include <WiFi.h>
//Waiting for Client, to choose which LED to Pin
// Static IP Configuration
IPAddress localIP(192, 168, 178, 152); // Set static IP address (use any available IP in your network range)
WiFiServer server(80); // Server will listen on port 80 (HTTP)
const int builtInLED = LED_BUILTIN; // Built-in LED pin on the Arduino R4 Wi-Fi
bool ledStatus = LOW; // Initial LED status (LOW = OFF)
// Connect to WiFi with static IP configuration
WiFi.config(localIP, gateway, subnet);
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
// Start the server
server.begin();
Serial.println("Server started");
Serial.print("Server IP Address: ");
Serial.println(WiFi.localIP()); // Print the static IP address of the server
pinMode(builtInLED, OUTPUT); // Set the LED pin as output
digitalWrite(builtInLED, ledStatus); // Set the initial LED state
WiFiClient client = server.available();
if (client) {
if (client.connected()){
Serial.println("client connected");
delay (10);
String request = "";
request = client.readStringUntil('\r');
Serial.print("Request: " );
Serial.println(request);
// Handle the LED status request
if (request.indexOf("LED_STATUS") != -1) {
client.print("LED Status: ");
client.println(ledStatus == HIGH ? "ON" : "OFF");
Serial.print("LED Status: ");
Serial.println(ledStatus == HIGH ? "ON" : "OFF");
Serial.println("LED status sent to client");
// Handle the toggle LED request
if (request.indexOf("TOGGLE_LED") != -1) {
ledStatus = (ledStatus == LOW) ? HIGH : LOW; // Toggle LED status
digitalWrite(builtInLED, ledStatus); // Set the LED to the new status
client.print("LED is now ");
Serial.println("LED status toggled");
client.stop();
Serial.println("Client disconnected");
Output wise I see on the sub:
Request: LED_STATUS
LED Status: OFF
Client disconnected
So I know this direction works, but the Main board gives me this:
Connected to server
Probably the solution is pretty simple, I already tried to find help in the internet, but the code parts I find are much more elaborate than what I try to achive.
Thank you in adavance for any hint, where I did a mistake.
