Hi everyone,
I am using Arduino RP2040 Connect for collecting IMU data and sending ti through WiFi Communication protocol.
I am actually using a client-server socket where this Arduino serves as first one (client) and Python serves as latter one (sever).
I am able to correctly connect Arduino to my Access Point, and to the server too. The communication works fine as long as Arduino stops generating data.
I see this bug by printing the data buffer which I want to send. In Serial Monitor I see data as long as a certain point they disappear, and obviously Python is not able to collect data anymore.
Here the most significant part of the code:
/* --- Include Arduino libraries --- */
/*** --------------- Variables --------------- ***/
unsigned long currentTime = 0, previousTime = 0, globalTime = 0;
int16_t deltaTime = 0;
int16_t nPacket = 0;
int16_t dataBuffer[BUFFER_LENGHT];
char c;
bool flag;
IMUsense LSM6DSOX_sensor; // IMU reading class
// Wi-Fi definitions
WiFiClient client; // Initialize the WiFi client library
String readString; // String for reiceving data
String end_payload = "ENDPAYLOAD"; // Payload MSG
/* ---------- SSID and PWD ----------- */
char ssid[] = "xxxxxxxxxxx"; // the name of your network
char pass[] = "xxxxxxxxxxx";
/* -------------- WiFi Parameters--------------- */
byte mac[] = {0x08, 0x3A, 0xF2, 0xB1, 0x9D, 0xE0}; // MAC Address Arduino
IPAddress ip(192, 168, 43, 98); // IP Address local network (Client)
IPAddress server(192,168,0,100); //access point
void Sensors_Reading(void) {
// ---------- LED ----------
digitalWrite(LED_WIFI, LOW); // Blue LED - wireless connection
digitalWrite(LED_ON, HIGH); // Green LED - power on
// ---------- Serial COM startup ----------
Serial.begin(921600); // Initialize data rate at 921.600 bps
#if defined(COM_SERIAL_ENABLE)
while (!Serial) {
; // wait for serial port to connect. Needed for native USB
Serial.println("Start!");
delay(5);
#endif // COM_SERIAL_ENABLE
// ---------- IMU initialization ----------
Serial.println("IMU initialization...");
if (!IMU.begin()) {
Serial.println("Failed!");
while (1);
Serial.print("Accelerometer sample rate = ");
Serial.print(IMU.accelerationSampleRate());
Serial.println(" Hz");
Serial.print("Gyroscope sample rate = ");
Serial.print(IMU.gyroscopeSampleRate());
Serial.println("IMU ready");
// ---------- WiFi initialization ----------
#if defined(COM_WIFI_ENABLE)
// Start WiFi
WiFi.begin(ssid,pass);
Serial.println("Connected to WiFi...");
// give WiFi 3 seconds to initialize:
Serial.println("connecting...");
delay(3000);
if (client.connect(server,port)) {
// Print result
Serial.println("Connection Done");
else {
Serial.println("Connection Failed");
#endif
Serial.println("Starting acquisition..."); // Exit from setup, start "loop()"
delay(100); // Wait a bit, then start!
previousTime = millis(); // Take current time
// if there are incoming bytes available
// from the server, read them and store them:
if (client.available()) {
c = client.read();
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting. . .");
client.stop();
// do nothing:
while(true);
// ---------- Sensors Acquisition ----------
if ( (millis()-previousTime) > SAMPLING_TIME-1 ) {
Sensors_Reading();
if (flag) {
client.write((byte*) dataBuffer, sizeof(dataBuffer)); // Data Buffer sending
Serial.println(dataBuffer[0]);
Serial.println(dataBuffer[1]);
Serial.println(dataBuffer[2]);
Serial.println(dataBuffer[3]);
Serial.println(dataBuffer[4]);
Serial.println(dataBuffer[5]);
Serial.println(dataBuffer[6]);
Serial.println(dataBuffer[7]);
Serial.println(dataBuffer[8]);
Serial.println(dataBuffer[9]);
Serial.println(dataBuffer[10]);
Serial.println(dataBuffer[11]);
Serial.println(dataBuffer[12]);
Has anyone any idea how to solve it?
Thanks.
