client.write() is getting halted in between for a few seconds
I am using ESP32 as a server and writing data received on UART1 to client and using client.write function.
The problem i am encountering with is that data is received continuously after each second but ESP32 is writing in chunks like it is getting halted in between and writing the chunk of data received simultaneously.
And what is the mode which is it following in writing to client i.e, packet or Stream mode
Please help me to solve this issue.
AKANSHA
Do you think that it might help if you posted your sketch ?
I am posting code of counter that is writing counts on client.
#include "EEPROM.h"
#include <WiFi.h>
#include <Wire.h>
WiFiServer server(80);
#define MAX_CLIENTS 10
#define EEPROM_SIZE 4
WiFiClient *clients[MAX_CLIENTS] = { NULL };
WiFiClient client;
const char* host = "192.168.98.159";
const int port = 90;
int SIZE;
int num;
char ssid [15];
char password[15];
char temp1 [15];
char temp2 [15];
int addr;
uint8_t ipBuffer[4];
uint8_t gwayBuffer[4];
String inp_cmd = "";
String serialResponse = "";
char x[10];
char y[10];
int i=0;
    EEPROM.begin(100);
    if(EEPROM.read(4) == 255)
     uint8_t ipBuffer[4] = {10,108,124,5};
     uint8_t gwayBuffer[4] ={10,108,124,10};
     char ssid[15] = "Smart_Move";
     char password[15] = "addverb@123";
     addr = 0;
      // Write in EEPROM
      for (int i = 0; i < 4; i++) {
        EEPROM.write(addr, ipBuffer[i]);
        addr += 1;}
      EEPROM.commit();
      addr = 5;
      for (int i = 0; i < 12; i++) {
        EEPROM.write(addr, ssid[i]);
        addr += 1;}
      EEPROM.commit();
      addr = 20;
        EEPROM.write(addr, password[i]);
        addr += 1;}
      EEPROM.commit();
      addr = 35;
        EEPROM.write(addr, gwayBuffer[i]);
        addr += 1;}
      EEPROM.commit();
      //IP Details
     IPAddress local_IP(ipBuffer[0], ipBuffer[1], ipBuffer[2], ipBuffer[3]);
     IPAddress gateway(gwayBuffer[0], gwayBuffer[1],gwayBuffer[2],gwayBuffer[3]);
     IPAddress subnet(255, 255, 255, 0);
     IPAddress primaryDNS(8, 8, 8, 8);
     IPAddress secondaryDNS(8, 8, 4, 4);
     if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
     Serial.println("STA Failed to configure");}
     // Connect to Wi-Fi network with SSID and password
     WiFi.begin(ssid, password);
     Serial.print(".");}
    // Print local IP address and start web server
     server.begin();
     uint8_t sta = 111;
     EEPROM.write(4,sta);
     EEPROM.commit();
     Serial.println(EEPROM.read(4));
    ipBuffer[i] = EEPROM.read(i);}
    ssid[i] = EEPROM.read(i+5);}
    password[i] = EEPROM.read(i+20);}
    gwayBuffer[i] = EEPROM.read(i+35);}
    Serial.print(".");}
    server.begin();}
  // Check if a new client has connected
   WiFiClient newClient = server.available();
   if (newClient) {
   Serial.println("new client");
  // Find the first unused space
   for (int i=0 ; i<MAX_CLIENTS ; ++i) {
   if (NULL == clients[i]) {
     clients[0] = new WiFiClient(newClient);
   if(NULL != clients[0] && clients[0]->connected() && clients[0]->available())
    clients[0]->println(i);
    i++;
Regards
AKANSHA
