Hello, I am interstead in generating a 8mhz clock output using my arduino uno how do I divide the arduino uno 16mhz clock and output to a pin?
// Use of timer2 to generate a signal for a particular frequency on pin 11
const int freqOutputPin = 11; // OC2A output pin for ATmega328 boards
//const int freqOutputPin = 10; // OC2A output for Mega boards
// Constants are computed at compile time
// If you change the prescale value, it affects CS22, CS21, and CS20
// For a given prescale value, the eight-bit number that you
// load into OCR2A determines the frequency according to the
// following formulas:
// With no prescaling, an ocr2val of 3 causes the output pin to
// toggle the value every four CPU clock cycles. That is, the
// period is equal to eight slock cycles.
// With F_CPU = 16 MHz, the result is 2 MHz.
// Note that the prescale value is just for printing; changing it here
// does not change the clock division ratio for the timer! To change
// the timer prescale division, use different bits for CS22:0 below
const int prescale = 1;
const int ocr2aval = 3;
// The following are scaled for convenient printing
// Period in microseconds
const float period = 2.0 * prescale * (ocr2aval+1) / (F_CPU/1.0e6);
// Frequency in Hz
const float freq = 1.0e6 / period;
pinMode(freqOutputPin, OUTPUT);
// Set Timer 2 CTC mode with no prescaling. OC2A toggles on compare match
// WGM22:0 = 010: CTC Mode, toggle OC
// WGM2 bits 1 and 0 are in TCCR2A,
// WGM2 bit 2 is in TCCR2B
// COM2A0 sets OC2A (arduino pin 11 on Uno or Duemilanove) to toggle on compare match
TCCR2A = ((1 << WGM21) | (1 << COM2A0));
// Set Timer 2 No prescaling (i.e. prescale division = 1)
// CS22:0 = 001: Use CPU clock with no prescaling
// CS2 bits 2:0 are all in TCCR2B
TCCR2B = (1 << CS20);
// Make sure Compare-match register A interrupt for timer2 is disabled
TIMSK2 = 0;
// This value determines the output frequency
OCR2A = ocr2aval;
Serial.print("Period = ");
Serial.print(period);
Serial.println(" microseconds");
Serial.print("Frequency = ");
Serial.print(freq);
Serial.println(" Hz");
// Do (almost) anything you want here. Just don't do analogWrite to
// pins controlled by Timer 2. In fact, don't do anything that messes
// with the registers in Timer 2.
Try Figuring it out from here, Regards Simon
const float period = 5.0 * prescale * (ocr2aval+1) / (F_CPU/1.0e6);
// Frequency in Hz
TIMSK2 = 0;
OCR2A = ocr2aval;
Serial.print(freq);
Well I decided to do the timer work for you, I tested it out on my Arduino Mega 2560 and I got it to 8MHZ Regards Simon
I have my osciloscope set to .05 micro seconds counted 5 divisions did
.00000005 *5 (repical) = 4,000,000 (4mhz) not 8 why is that?
Could It be that I used the Mega while testing it?
