I am using a vellman vma301 clock module (DS1302) with an arduino uno. I can seem to set the time on it. I am using the sketch below
// Example sketch for interfacing with the DS1302 timekeeping chip.
// Copyright (c) 2009, Matt Sparks
// All rights reserved.
// http://quadpoint.org/projects/arduino-ds1302
#include <stdio.h>
#include <DS1302.h>
namespace {
// Set the appropriate digital I/O pin connections. These are the pin
// assignments for the Arduino as well for as the DS1302 chip. See the DS1302
// datasheet:
// http://datasheets.maximintegrated.com/en/ds/DS1302.pdf
const int kCePin = 5; // Chip Enable
const int kIoPin = 6; // Input/Output
const int kSclkPin = 7; // Serial Clock
// Create a DS1302 object.
DS1302 rtc(kCePin, kIoPin, kSclkPin);
String dayAsString(const Time::Day day) {
switch (day) {
case Time::kSunday: return "Sunday";
case Time::kMonday: return "Monday";
case Time::kTuesday: return "Tuesday";
case Time::kWednesday: return "Wednesday";
case Time::kThursday: return "Thursday";
case Time::kFriday: return "Friday";
case Time::kSaturday: return "Saturday";
return "(unknown day)";
void printTime() {
// Get the current time and date from the chip.
Time t = rtc.time();
// Name the day of the week.
const String day = dayAsString(t.day);
// Format the time and date and insert into the temporary buffer.
char buf[50];
snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",
day.c_str(),
t.yr, t.mon, t.date,
t.hr, t.min, t.sec);
// Print the formatted string to serial so we can see the time.
Serial.println(buf);
} // namespace
// Initialize a new chip by turning off write protection and clearing the
// clock halt flag. These methods needn't always be called. See the DS1302
// datasheet for details.
rtc.writeProtect(false);
rtc.halt(false);
// Make a new time object to set the date and time.
// Sunday, September 22, 2013 at 01:38:50.
Time t(2014, 5, 10, 15, 8, 50, Time::kThursday);
// Set the time and date on the chip.
rtc.time(t);
// Loop and print the time every second.
printTime();
If i am understanding the direction correctly, when i run this code, the date on my serial monitor should change to Thursday September 5 2014 at 15:08: 50 . Instead what i am getting is Sunday 2019-03-07 20:46:35
I have RST connected to pin5
DAT to pin 6
CLK to pin 7
Anyone have an idea why?
JG
