I am using millis for 16x2 LCD clock project. it is counting seconds, minutes and hours. it is starting 00:00:00 (hh:mm:ss). and after when the time 09:06:07, LCD stop. I tried 3 times and it stop 09:06:07. LCD screen is freezing but arduino LED is blinking. I did not look serial port screen.
Why does it stop?. I did not wanted to use RTC module. is it impossible to make a clock with 24hours clock? if it is impossible, I can use RTC-module, but firstly I want to learn, why it is stop at the same time.
I am using Arduino-nano-Atmega328P and 1602 LCD Display
MY codes are bottom.
#include <Wire.h>
LiquidCrystal_I2C lcd {0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE};
int starttime;
int activetime;
int prevoustime = 0;
int hours = 0;
int mins = 0;
int secs = 0;
lcd.begin(16, 2);
lcd.clear();
starttime = millis() / 1000;
activetime = (millis() / 1000) - starttime;
if (prevoustime < activetime)
secs++;
prevoustime = activetime;
if (secs > 59)
mins++;
secs = 0;
if (mins > 59)
hours++;
mins = 0;
if (hours > 23)
hours = 0;
lcd.setCursor(0, 0);
if (hours < 10)
lcd.print("0");
lcd.print(hours);
lcd.print(hours);
lcd.print(":");
if (mins < 10)
lcd.print("0");
lcd.print(mins);
lcd.print(mins);
lcd.print(":");
if (secs < 10)
lcd.print("0");
lcd.print(secs);
lcd.print(secs);
delay(100);
lcd.clear();
Serial.println(mins);
Serial.println(hours);
Serial.println("");
Serial.println("");
Serial.println(activetime);
Serial.println(prevoustime);
Serial.println(starttime);
Serial.println("");
TheMemberFormerlyKnownAsAWOL:
An int stores values in the range -32768 to +32767
thank you for help. 32767 seconds later it stop. Ok. I understood. I deleted seconds counter codes. But at this position it will stop 32767 mins later. Right? Then what can i do? Self reset ? Or what? Or do i need another store? Unsigned long?
hammy:
You might want to also look at variable types to understand the differences and range of values they can hold.
Google can help you here .
Or just look at the Arduino documentation:
On the Arduino Uno (and other ATmega based boards) an int stores a 16-bit (2-byte) value. This yields a range of -32,768 to 32,767 (minimum value of -2^15 and a maximum value of (2^15) - 1).(16 bits, -32k to +32k)
On the Uno and other ATMEGA based boards, unsigned ints (unsigned integers) are the same as ints in that they store a 2 byte value. Instead of storing negative numbers however they only store positive values, yielding a useful range of 0 to 65,535 ((2^16) - 1).
Long variables are extended size variables for number storage, and store 32 bits (4 bytes), from -2,147,483,648 to 2,147,483,647.
Unsigned long variables are extended size variables for number storage, and store 32 bits (4 bytes). Unlike standard longs unsigned longs won’t store negative numbers, making their range from 0 to 4,294,967,295 (2^32 - 1).
hannah_mackinlay:
... and guess how many seconds there are in 09:06:07?
