Clock
Hi guys. I have an Eleven, a 16x2 lcd and a ds3232 clock. From everything I read its simple. I've tried every code I can find to get this thing working but I just keep getting error codes, too many to list in the one code. Is there somewhere I can read that has a step by step for noobs that stops me from chucking it in the corner.
Chris
But you're not going to share them
So, attach them.
Post your code.
Use code tags.
Indeed, without the code, we will not be able to help you as such.
Please upload the code (Using code tags) so the we can review it and see if we can help you.
Yours sincerely,
-Goldfile
This will do:
// Project 58 - Creating a Simple Digital Clock
#include "Wire.h"
#define DS3232_I2C_ADDRESS 0x68
#include <LiquidCrystal.h>
LiquidCrystal lcd( 8, 9, 4, 5, 6, 7 );
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return( (val/16*10) + (val%16) );
  Wire.begin();
  lcd.begin(16, 2);
  // set the initial time here:
  // DS3232 seconds, minutes, hours, day, date, month, year
  //setDS3232time(0, 27, 0, 5, 15, 11, 12);
void setDS3232time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
  // sets time and date data to DS3232
  Wire.beginTransmission(DS3232_I2C_ADDRESS);
  Wire.write(0); // set next input to start at the seconds register
  Wire.write(decToBcd(second)); // set seconds
  Wire.write(decToBcd(minute)); // set minutes
  Wire.write(decToBcd(hour)); // set hours
  Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
  Wire.write(decToBcd(dayOfMonth)); // set date (1 to 31)
  Wire.write(decToBcd(month)); // set month
  Wire.write(decToBcd(year)); // set year (0 to 99)
  Wire.endTransmission();
void readDS3232time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
  Wire.write(0); // set DS3232 register pointer to 00h
  Wire.requestFrom(DS3232_I2C_ADDRESS, 7);
  // request seven bytes of data from DS3232 starting from register 00h
  *second = bcdToDec(Wire.read() & 0x7f);
  *minute = bcdToDec(Wire.read());
  *hour = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month = bcdToDec(Wire.read());
  *year = bcdToDec(Wire.read());
void displayTime()
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  // retrieve data from DS3232
  readDS3232time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
  &year);
  // send the data to the LCD shield
  lcd.clear();
  lcd.setCursor(4,0);
  lcd.print(hour, DEC);
  lcd.print(":");
  if (minute<10)
    lcd.print("0");
  lcd.print(minute, DEC);
  lcd.print(":");
  if (second<10)
    lcd.print("0");
  lcd.print(second, DEC);
  lcd.setCursor(0,1);
  switch(dayOfWeek){
  case 1:
    lcd.print("Sun");
  case 2:
    lcd.print("Mon");
  case 3:
    lcd.print("Tue");
  case 4:
    lcd.print("Wed");
  case 5:
    lcd.print("Thu");
  case 6:
    lcd.print("Fri");
  case 7:
    lcd.print("Sat");
  lcd.print(" ");
  lcd.print(dayOfMonth, DEC);
  lcd.print("/");
  lcd.print(month, DEC);
  lcd.print("/");
  lcd.print(year, DEC);
  displayTime(); // display the real-time clock time on the LCD,
  delay(1000); // every second
