Hi there
Running on OS X Catalina on a MacBook Pro with an external 30 inch display connected through USB C with a Thunderbolt 3 Express Dock. Arduino version 1.8.12
For some reason my external display looses power (T° protection) intermittently and all the windows thus are moved back to the Laptop display — well not quite all of them, only the Arduino IDE dies in the process. This was not the case prior to 1.8.12
EDIT: And actually the issue appears as soon as you move a window from one Screen to the other. Just tried moving the Serial Monitor to my embedded screen and the IDE died.
[size=8pt][color=green]Model: MacBookPro16,1, BootROM 1037.100.359.0.0 (iBridge: 17.16.14263.0.0,0), 8 processors, 8-Core Intel Core i9, 2,3 GHz, 32 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Graphics: kHW_AMDRadeonPro5500MItem, AMD Radeon Pro 5500M, spdisplays_pcie_device, 8 GB
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2667 MHz, Micron, -
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2667 MHz, Micron, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Feb 28 2020 15:31:53 version 9.30.357.35.32.5.47 FWID 01-29ff5c69
Bluetooth: Version 7.0.4f6, 3 services, 27 devices, 1 incoming serial ports
Network Service: Thunderbolt Ethernet Slot 1, Ethernet, en7
Network Service: Wi-Fi, AirPort, en0
PCI Card: ethernet, sppci_ethernet, Thunderbolt@71,0,0
PCI Card: pci1b73,1100, sppci_usbxhci, Thunderbolt@72,0,0
USB Device: Mobile Drive
USB Device: USB 3.1 Bus
USB Device: USB 3.0 Bus
USB Device: 4-Port USB 3.0 Hub
USB Device: USB audio CODEC
USB Device: Hub
USB Device: Hub
USB Device: Apple Cinema HD Display
USB Device: 4-Port USB 2.0 Hub
USB Device: Apple T2 Bus
USB Device: Composite Device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 55.3
Thunderbolt Device: Thunderbolt 3 Express Dock HD, Belkin International, Inc., 3, 19.1
Thunderbolt Bus: MacBook Pro, Apple Inc., 55.3[/color]
[color=blue]Process: Arduino [61310]
Path: /Applications/Arduino.app/Contents/MacOS/Arduino
Identifier: cc.arduino.Arduino
Version: 1.8.12 (1.8.12)
Code Type: X86-64 (Native)
Parent Process: ? ? ? [1]
Responsible: Arduino [61310]
User ID: 501
Date/Time: 2020-04-07 10:10:58.435 +0200
OS Version: Mac OS X 10.15.4 (19E266)
Report Version: 12
Bridge OS Version: 4.4 (17P4263)
Anonymous UUID: 7933063B-2CC7-44BB-A38A-9D8E6C6ACBE9
Sleep/Wake UUID: CA656DFE-CF1F-47E4-AB6C-9B73431FC2E6
Time Awake Since Boot: 210000 seconds
Time Since Wake: 26 seconds
System Integrity Protection: enabled
Crashed Thread: 35 Java: Java2D Queue Flusher
Exception Type: EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.[/color]
[/size]
