[Closed] Fail When It Have Too Many IF, ELSE IF??
PROBLEM
I have the problem that the Serial Monitor is not functional (no incoming data or unknown result) when I provided too many if, else if (more than 3 if, else if **below code "misubishi() Function") . However,when I comment some of it out everythings work fine!
NOTE
I have already set Baud Rate @ 57600, also the same with Serial.Begin()
I have already test all if and else if statement work.
my board is Arduino Uno.
Binary sketch size: 14,478 bytes (of a 32,256 byte maximum).
EDIT
Added All Code in problem sketch. - 6/13/2014
Added Answer - 7/13/2014
Deleted Unnecessary Code...
ANWSER
This is a solution for my case, it's about use of memory (SRAM)
problem in mitsubishi() that I assign many unsigned int code[] and it over SRAM limit
use of PROGMEM instead
so, it is not about TOO Many If, else if .
REF.
http://forum.arduino.cc/index.php?topic=201031.0
misubishi() FUNCTION
void mitsubishi(char* data){
    int khz=38;
    if (strcmp((char*)msg,"off") == 0)
//      Serial.println("send -> OFF");
      unsigned int code[] = {3150,1550,999,999,999,1111,450,000,999,999,999,1200,999,999,999,1111,999,999,999,999,999,1111,999,1200,999,1200,999,000,999,1200,999,999,999,1111,999,1200,999,1200,999,000,999,999,999,999,999,999,999,1111,999,1200,999,999,999,1111,999,1200,999,999,999,999,999,1111,999,999,999,999,999,1111,450,000,999,999,999,1200,999,1111,999,999,999,1200,999,1111,999,1200,999,1111,450,1111,999,1200,999,000,450,1111,999,999,999,1111,450,000,999,999,999,999,999,999,999,1111,999,999,999,1200,999,999,999,1111,999,1200,999,1111,999,1200,999,1200,999,000,999,999,999,1200,999,999,999,000,999,999,999,999,999,999,999,1111,999,1200,999,999,999,999,999,1111,999,1200,999,1111,450,1111,999,999,000,1200,450,000,999,1200,999,999,999,000,450,000,999,999,999,1200,999,000,450,1111,999,1000};
      irsend.sendRaw(code,sizeof(code)/sizeof(int),khz);
    else if (strcmp((char*)msg,"on/27") == 0)
//      Serial.println("send -> ON, @ 27 degree");
      unsigned int code[] = {3200,1550,999,000,450,1111,450,000,450,000,999,1111,450,000,450,1111,999,000,450,000,450,1111,450,1111,999,1111,450,000,450,1111,999,000,450,1111,450,1111,999,1111,450,000,450,000,999,999,999,000,450,1111,450,1111,999,000,450,1111,450,1111,999,000,450,000,450,1111,999,999,999,000,450,1111,450,000,999,999,999,1111,450,1111,999,999,999,1111,450,1111,999,1111,450,1111,450,1111,999,1111,450,000,450,1111,999,000,450,1111,450,000,999,999,999,000,450,000,450,1111,999,999,999,1111,450,000,450,1111,999,1111,450,1111,999,1111,450,1111,999,1200,999,1111,450,1111,999,999,999,000,450,000,450,000,450,000,999,999,999,000,450,000,450,000,450,1111,999,1111,450,000,450,1111,999,000,450,1111,450,000,450,1100,450,000,450,000,450,1111,999,999,999,1111,450,000,450,1111,999,1000};
    else if (strcmp((char*)msg,"on/26") == 0)
//      Serial.println("send -> ON, @ 26 degree");
      unsigned int code[] = {3150,1550,999,999,450,1111,999,000,450,000,450,1111,999,999,999,1111,999,999,999,999,999,1111,999,1200,999,1200,999,000,999,1200,999,999,999,1111,999,1200,450,1111,999,000,999,999,999,999,999,999,999,1111,450,1111,999,999,999,1111,450,1111,999,999,999,999,999,1111,450,000,450,000,999,1111,450,000,450,000,450,1111,999,1111,450,000,450,1111,999,1111,450,1111,999,1200,999,1111,450,1111,999,999,999,1111,450,000,450,1111,999,000,450,000,450,000,450,000,999,1111,450,000,450,1111,999,999,999,1111,450,1111,999,1111,450,1111,450,1111,999,1111,450,1111,999,1111,450,000,450,000,450,000,999,999,999,000,450,000,450,000,999,999,999,999,999,1111,999,1200,999,1111,999,999,999,1200,999,1111,999,999,999,1200,999,999,999,000,999,999,999,1200,999,999,999,000,999,1200,999,1000};
    else if (strcmp((char*)msg,"on/25") == 0)
//      Serial.println("send -> ON, @ 25 degree");
      unsigned int code[] = {3200,1550,999,000,450,1111,450,000,999,999,999,1111,450,000,450,1111,999,000,450,000,450,1111,450,1100,450,1111,450,000,450,1100,450,000,450,1111,450,1100,450,1111,450,000,450,000,999,000,450,000,450,1111,450,1111,999,000,450,1111,450,1111,999,000,450,000,450,1111,999,999,999,000,999,1200,999,999,999,999,999,1111,999,1200,999,999,999,1111,999,1200,999,1111,450,1111,999,1200,999,1111,999,999,999,1200,999,000,999,1200,999,999,999,999,999,000,999,999,999,1200,999,999,999,1111,999,999,999,1200,999,1111,999,1200,999,1111,450,1111,999,1200,999,1111,450,1111,999,999,999,000,450,000,450,000,450,000,999,999,999,000,450,000,450,000,450,1111,999,1111,450,000,450,1111,999,1111,450,1111,999,999,999,1111,450,000,450,000,999,1200,999,000,450,000,450,000,450,1111,999,1000};
    else if (strcmp((char*)msg,"on/20") == 0)
//      Serial.println("send -> ON, @ 20 degree");
      unsigned int code[] = {3200,1500,450,000,450,1111,450,000,999,000,450,1111,450,000,450,1100,450,000,450,000,450,1111,999,1111,450,1111,450,000,999,1111,450,000,450,1111,999,1111,450,1111,450,000,999,999,999,000,450,000,450,1111,999,1111,450,000,450,1111,999,1111,450,000,450,000,450,1111,999,000,450,000,450,1111,999,999,999,000,450,1111,450,1111,999,000,450,1111,999,1200,999,1111,999,1200,999,1111,450,1111,450,000,999,1111,450,000,450,1111,999,999,999,000,450,000,450,000,450,1111,999,000,450,1111,450,000,450,1100,450,1111,450,1111,999,1111,450,1111,450,1111,999,1111,450,1111,999,999,999,000,450,000,450,000,450,000,999,999,999,000,450,000,450,000,450,1100,450,1111,450,000,450,000,999,999,999,1111,450,1111,999,1111,450,000,450,000,450,1111,999,1111,450,1111,999,999,999,000,450,1000};
    else if (strcmp((char*)msg,"info") == 0)
//      Serial.println("send -> Fetch Temperature Info.");
      steps();
      radio.startListening();
//      Serial.println("send -> Nothings.");
You have a bug with your code. Your problem is not with the serial monitor!. So post all of your code!
Mark
I have edited my question. Thank for your respond.
Please post your code as a single unit rather than in pieces.
Also, please point out the part that has all of the IF statements that are causing problems.
As @holmes4 said there is NO possibility that the problem lies in the serial moniotr and I don't understand how you thought there might be. There is no means for the serial monitor to know what code is on your Arduino.
...R
That makes it sound suspiciously like you have a problem with shortage of memory and you do have some large arrays of ints in the program.
void loop(void)
  //check for any incoming message
  if (radio.available())
    bool done = false;
    while (!done)
      // Fetch the payload, and see if this was the last one.
      done = radio.read(msg,sizeof(msg));
    }//end while
    Serial.println((char*) msg);
    mitsubishi((char*)msg);
  }//end if incomming radio
}//end loop
Start by sorting out the above code.
  1. That does radio.read return - I am sure it is not a boolean!,
  2. msg should be a char array not int - if your having to put in a lot of explicit casts something is worng
  3. Why are you using a while in side loop(), loop is just called over and over, the trick is to avoid using for/while in loop()
  4. do you real want to print just the last message?
  5. strings passed to print/println MUST be null terminated you will screw up printing if they are not!
Mark
This post (Multiple "else if" problem - Project Guidance - Arduino Forum) is a SOLUTION for me.
Exactly the same problem, it's about use of memory (SRAM)
Thank you for all. :slight_smile:
