closed loop stepper motor
so im trying to make a closed loop program i already have the code i attached on this post, hope i can get some help, i can move the motor in both directions with an encoder.
stepnuevo.ino (4.02 KB)
How your sketch should have been posted:
// EasyDriver connections
#define step_pin 4  // Pin 9 connected to Steps pin on EasyDriver
#define dir_pin 5   // Pin 8 connected to Direction pin
volatile boolean TurnDetected;  // need volatile for Interrupts
volatile boolean rotationdirection;  // CW or CCW rotation
// Rotary Encoder Module connections
const int PinCLK = 2; // Generating interrupts using CLK signal
const int PinDT = 3;  // Reading DT signal
const int PinSW = 6;  // Reading Push Button switch
int long encoder0PinA = 2;
int long encoder0PinB = 3;
int long encoder0Pos = 0;
int encoder0PinALast = LOW;
int n = LOW;
float grados = 0;
int StepperPosition = 0;  // To store Stepper Motor Position
int StepsToTake = 86;    // Controls the speed of the Stepper per Rotary click
int direction;   // Variable to set Rotation (CW-CCW) of stepper
// Interrupt routine runs if CLK goes from HIGH to LOW
void rotarydetect ()
  delay(4);  // delay for Debouncing
  if (digitalRead(PinCLK))
    rotationdirection = digitalRead(PinDT);
    rotationdirection = !digitalRead(PinDT);
  TurnDetected = true;
void setup ()
  pinMode(dir_pin, OUTPUT);
  pinMode(step_pin, OUTPUT);
  pinMode(PinCLK, INPUT); // Set Pin to Input
  pinMode(PinDT, INPUT);
  pinMode(PinSW, INPUT);
  digitalWrite(PinSW, HIGH); // Pull-Up resistor for switch
  attachInterrupt (0, rotarydetect, FALLING); // interrupt 0 always connected to pin 2 on Arduino UNO
void loop ()
  if (!(digitalRead(PinSW)))     // check if button is pressed
    if (StepperPosition == 0)    // check if button was already pressed
      if (StepperPosition > 0)    // Stepper was moved CW
        while (StepperPosition != 0)   //  Do until Motor position is back to ZERO
          digitalWrite(dir_pin, HIGH);  // (HIGH = anti-clockwise / LOW = clockwise)
          for (int x = 1; x < StepsToTake; x++)
            digitalWrite(step_pin, HIGH);
            delay(1);
            digitalWrite(step_pin, LOW);
            delay(1);
          StepperPosition = StepperPosition - StepsToTake;
          digitalWrite(dir_pin, LOW);  // (HIGH = anti-clockwise / LOW = clockwise)
            delay(1);
            delay(1);
          StepperPosition = StepperPosition + StepsToTake;
      grados = 0; // Reset position to ZERO after moving motor back
  // Runs if rotation was detected
  if (TurnDetected)
    TurnDetected = false;  // do NOT repeat IF loop until new rotation detected
    // Which direction to move Stepper motor
    if (rotationdirection)   // Move motor CCW
        delay(1);
        delay(1);
    if (!rotationdirection)   // Move motor CW
        delay(1);
        delay(1);
  n = digitalRead(encoder0PinA);
  if ((encoder0PinALast == LOW) && (n == HIGH))
    if (digitalRead(encoder0PinB) == LOW)
      encoder0Pos--;
      grados = ((encoder0Pos * 360 / 20));
      if (encoder0Pos == -20)
        (encoder0Pos = 0);
      encoder0Pos++;
      if (encoder0Pos == 20)
        (encoder0Pos = 0);
    Serial.print(" GRADOS = ");
    Serial.println (grados);
  encoder0PinALast = n;
ebenezer2301:
What do you need help with?
What sort of encoder are you using? Is it being moved by the motor or the user's hand?
Post a link to the encoder datasheet.
...R
