I am fairly new to coding and am having trouble getting my code to reach the LOW button state. It is basically a six mode led light with a button state change. I want it to turn off on the 6th button push but the RGB remains on, not going to the final light mode (solid) or off.
Here is my code:
int redPin = 3;
int bluePin = 4;
int greenPin = 5;
int redIn = 0;
int greenIn = 1;
int blueIn = 2;
int redVal;
int greenVal;
int blueVal;
int switchPin = 2; // switch is connected to pin 2
int led1Pin = 12;
int led2Pin = 11;
int led3Pin = 10;
int led4Pin = 9;
int led5Pin = 8;
int val; // variable for reading the pin status
int val2; // variable for reading the delayed status
int buttonState; // variable to hold the button state
int lightMode = 0; // What mode is the light in?
int tim = 50;
Serial.begin(9600); // Set up serial communication at 9600bps
buttonState = digitalRead(switchPin); // read the initial state
pinMode(switchPin, INPUT); // Set the switch pin as input
pinMode(led1Pin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(led3Pin, OUTPUT);
pinMode(led4Pin, OUTPUT);
pinMode(led5Pin, OUTPUT);
redVal = 255;
greenVal = 255;
blueVal = 255;
update();
// This function updates the LED outputs.
void update()
analogWrite(redPin, redVal);
analogWrite(greenPin, greenVal);
analogWrite(bluePin, blueVal);
// This function updates one of the color variables
// either getting brighter or getting dimmer.
// It also updates the outputs and delays for 10 milliseconds.
void color_morph(int* value, int get_brighter)
for (int i = 0; i < 255; i++)
if (get_brighter)
(*value)--;
(*value)++;
update();
delay(10);
void loop(){
val = digitalRead(switchPin); // read input value and store it in val
delay(10); // 10 milliseconds is a good amount of time
val2 = digitalRead(switchPin); // read the input again to check for bounces
if (val == val2){ // make sure we got 2 consistant readings!
if (val != buttonState) { // the button state has changed!
if (val == LOW) { // check if the button is pressed
if (lightMode == 0) { // if its off
lightMode = 1; // turn lights on!
if (lightMode == 1) { // if its all-on
lightMode = 2; // make it blink!
if (lightMode == 2) { // if its blinking
lightMode = 3; // make it wave!
if (lightMode == 3) { // if its waving,
lightMode = 4; // make it cylon
if (lightMode == 4) { // if its cylon
lightMode = 5; // make it RGB
if (lightMode == 5) { // if its RGB
lightMode = 6; // make it solid
if (lightMode == 6) { // if its solid
lightMode = 0; // turn it off
buttonState = val; // save the new state in our variable
// Now do whatever the lightMode indicates
if (lightMode == 0) { // all-off
Serial.println ("Off");
digitalWrite(led1Pin, LOW);
digitalWrite(led2Pin, LOW);
digitalWrite(led3Pin, LOW);
digitalWrite(led4Pin, LOW);
digitalWrite(led5Pin, LOW);
Serial.println ("Solid");
digitalWrite(led1Pin, HIGH);
digitalWrite(led2Pin, HIGH);
digitalWrite(led3Pin, HIGH);
digitalWrite(led4Pin, HIGH);
digitalWrite(led5Pin, HIGH);
delay(100);
Serial.println ("Blink");
delay(100);
delay(100);
if (lightMode == 3){
Serial.println ("Cylon");
digitalWrite(led1Pin, HIGH); //turns led1 on, or HIGH
delay(tim); //wait for tim miliseconds
digitalWrite(led2Pin, HIGH);//and so on
delay(tim);
digitalWrite(led1Pin, LOW);//turns led1 off, or LOW
delay(tim);// you get the point
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
delay(tim);
if (lightMode == 4){
Serial.println ("Wave");
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
Serial.println ("RGB");
color_morph(&redVal, 1); // transition to red
color_morph(&greenVal, 1); // transition to yellow
color_morph(&redVal, 0); // transition to green
color_morph(&blueVal, 1); // transition to aqua
color_morph(&redVal, 1); // transition to white
color_morph(&greenVal, 0); // transition to violet
color_morph(&redVal, 0); // transition to blue
color_morph(&blueVal, 0); // transition to black (all off)
if (lightMode == 6) { // all-on
I know it is something simple but I cant see the problem myself. Any and all help is appreciated.
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
