Cloud connection
Hi, I’m encountering an issue with connecting to the IoT cloud. Initially, everything functions correctly, but when I disconnect and reconnect my board, it fails to connect. I’ve found a temporary workaround by uploading the example ‘cloud blink’ sketch, which allows the device to connect and appear on the devices dashboard. Afterward, I re-upload my original sketch and hope it connects. Could you help me understand why this is happening?
Here is my code
#include <DHT.h>
#include <DHT_U.h>
#include "thingProperties.h"
#define DHTPIN 6     // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define LIGHT_PIN 5   // Pin connected to the light control
DHT_Unified dht(DHTPIN, DHTTYPE);
LiquidCrystal_I2C lcd(0x27, 20, 4);
bool lightState = false;
RTC_HandleTypeDef hrtc;
unsigned long timerStart = 0; // When the timer started (in millis)
unsigned long previousMillis = 0;
const long sensorInterval = 20000; // Interval to read the sensors (20 seconds)
  pinMode(LIGHT_PIN, OUTPUT);
  dht.begin();
  lcd.init();
  lcd.backlight();
  lcd.clear();
  initProperties();
  ArduinoCloud.begin(ArduinoIoTPreferredConnection, false);
  setDebugMessageLevel(4);
  ArduinoCloud.printDebugInfo();
  // Initialize the RTC
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  HAL_RTC_Init(&hrtc);
  ArduinoCloud.update();
  if (currentMillis - previousMillis >= sensorInterval) {
    readSensorsAndUpdate();
  manageLightScheduler();
  manageTimerDisplay();
void readSensorsAndUpdate() {
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if (isnan(event.temperature)) {
    Serial.println(F("Error reading temperature!"));
    float temperatureF = (event.temperature * 9.0 / 5.0) + 32; // Convert to Fahrenheit
    lcd.setCursor(0, 1);
    lcd.print("Temp: ");
    lcd.print(temperatureF);
    lcd.print(" F  ");
    temperature = temperatureF; // Update cloud variable
  dht.humidity().getEvent(&event);
  if (isnan(event.relative_humidity)) {
    Serial.println(F("Error reading humidity!"));
    lcd.setCursor(0, 0);
    lcd.print("Humidity: ");
    lcd.print(event.relative_humidity);
    lcd.print("%    ");
    humidity = event.relative_humidity; // Update cloud variable
void manageLightScheduler() {
  // Get the current date and time
  RTC_TimeTypeDef gTime;
  RTC_DateTypeDef gDate;
  HAL_RTC_GetTime(&hrtc, &gTime, RTC_FORMAT_BIN);
  HAL_RTC_GetDate(&hrtc, &gDate, RTC_FORMAT_BIN); // Must be called after GetTime
  // Adjust for EST (UTC-5)
  int currentHour = gTime.Hours - 5;
  if (currentHour < 0) {
    currentHour += 24; // Adjust day rollover
  // Scheduler logic
  if (scheduler) {
    if (currentHour >= 7 && currentHour < 19) {
      if (!lightState) {
        digitalWrite(LIGHT_PIN, HIGH);
        lightState = true;
        timerStart = millis();
      if (lightState) {
        digitalWrite(LIGHT_PIN, LOW);
        lightState = false;
  // Display the scheduler status on the LCD
  lcd.setCursor(0, 3);
  lcd.print(scheduler ? "Scheduler: ON " : "Scheduler: OFF");
void manageTimerDisplay() {
  if (lightState) {
    unsigned long currentTime = millis();
    unsigned long elapsedTime = currentTime - timerStart; // Elapsed time in milliseconds
    unsigned long elapsedSeconds = (elapsedTime / 1000) % 60; // Elapsed seconds
    unsigned long elapsedMinutes = (elapsedTime / 1000) / 60; // Elapsed minutes
    unsigned long elapsedHours = elapsedMinutes / 60; // Elapsed hours
    elapsedMinutes %= 60; // Remaining minutes after converting to hours
    lcd.setCursor(0, 2);
    lcd.print("Time: ");
    if (elapsedHours > 0) {
      lcd.print(elapsedHours);
      lcd.print("H ");
    lcd.print(elapsedMinutes);
    lcd.print("M ");
    lcd.print(elapsedSeconds);
    lcd.print("S        "); // Clear extra characters
    lcd.print("Light OFF        ");
void onLightChange() {
  digitalWrite(LIGHT_PIN, light ? HIGH : LOW);
  lightState = light;
  if (lightState) {
  Serial.print("Light changed to: ");
  Serial.println(light ? "ON" : "OFF");
void onSchedulerChange() {
  Serial.print("Scheduler changed to: ");
  Serial.println(scheduler ? "ON" : "OFF");
// Implement these functions if you need to act upon changes in humidity, temperature, or other properties
void onHumidityChange() {
  // Act upon Humidity change
void onTemperatureChange() {
  // Act upon Temperature change
