CLS command
I am trying to read in from the analog input.
My idea is to display the input, wait a moment, clear the screen and repeat.
The CLS and Clear commands are not working,
I have been looking but haven’t found anything to make this work.
#include <stdlib.h>
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
  // print out the value you read:
  Serial.println(sensorValue);
  delay(1);        // delay in between reads for stability
  Serial.println(clear);
You have not given the information needed to solve the problem - what screen are you trying to clear? Where is all your code? Have you read the sticky thread "Read this before posting a programming question..." ?
stdlib does not do anything with the Serial Monitor...
There isn't a way to clear the Serial Monitor built into the Arduino IDE...
