Hi all. I should start off by saying I'm completely new to arduino. Basically one of my X10 remotes is dying and I wanted to try and make a new one. I have the CM17. I copied the library from here: http://www.arduino.cc/playground/X10/CM17A
I pasted the example into a sketch and it immediately failed and wouldn't compile.(Errors are below) I copied the library to the libraries folder. I found a Wiring.c and Wire.h but no wiring.h. Does anyone know of another library? Any other ideas?
Thanks
AJ
Errors:
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:24:20: error: wiring.h: No such file or directory
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp: In member function 'void X10Firecracker::init(int, int, int)':
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:96: error: 'OUTPUT' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:96: error: 'pinMode' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp: In member function 'void X10Firecracker::sendCmd(HouseCode, int, CommandCode)':
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:103: error: 'byte' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:103: error: expected ;' before 'messageBuff'
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:118: error: 'messageBuff' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:125: error: 'LOW' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:125: error: 'digitalWrite' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:127: error: 'delay' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:129: error: 'HIGH' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:133: error: expected
;' before 'i'
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:133: error: 'i' was not declared in this scope
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:134: error: expected `;' before 'mask'
E:\Program Files\arduino\libraries\X10Firecracker\X10Firecracker.cpp:134: error: 'mask' was not declared in this scope
