Hi there,
I'm trying to get my clone Mega2560 (with CH340 chip) working with a program called SPAD.next. That program (which is for a flight simulator) provides a sample sketch. No errors when I validate the sample sketch, but the following errors show up when I upload it:
C:\Users\...\Documents\Arduino\libraries\CmdMessenger\CmdMessenger.cpp: In member function 'char* CmdMessenger::readStringArg()':
C:\Users\...\Documents\Arduino\libraries\CmdMessenger\CmdMessenger.cpp:492:9: warning: invalid conversion from 'char' to 'char*' [-fpermissive]
return '\0';
As of now, the SPAD.next program isn't even recognizing my clone Mega, even though I've used it with other programs successfully.
Some questions:
- Are the errors above consequential? In terms of Arduino, I'm a kindergartener.
- If so, what edits will solve those errors?
- Could the errors above be preventing SPAD.next from even recognizing the board?
- What do I put in the line after "// Unique Device ID: Change this!"? I'm guessing this should be the unique hardware ID of the Mega clone, but where exactly is that found? I looked in Device Manager, and there are several IDs that have the same format, but not sure which to use (Container ID, Class GUI ID, etc.).
Here is the sample sketch supplied by the SPAD.next program:
// *** SNDEMO ***
// This example shows how to autoconnect between the SPAD.neXt and Arduino.
// SPAD.neXt >= 0.9.7.5 required
// It demonstrates how to
// - Respond to a connection request from SPAD.neXt
// - Use a identifier to handshake
// - Expose a data value to SPAD.neXt
// - Request Data Updates from SPAD.neXt
#include <CmdMessenger.h> // CmdMessenger
// Internal led
const int ledPin = LED_BUILTIN;
// Listen on serial connection for messages from the pc
CmdMessenger messenger(Serial);
// This is the list of recognized commands. These can be commands that can either be sent
// or received.
// In order to receive, attach a callback function to these events
enum
kRequest = 0, // Request from SPAD.neXt
kCommand = 1, // Command to SPAD.neXt
kEvent = 2, // Events from SPAD.neXt
kDebug = 3, // Debug strings to SPAD.neXt Logfile
kSimCommand = 4, // Send Event to Simulation
kLed = 10, // CMDID for exposed data to SPAD.neXt
kHeading = 11, // CMDID for data updates from SPAD.neXt
int lastLedState = 999;
bool isReady = false;
void attachCommandCallbacks()
// Attach callback methods
messenger.attach(onUnknownCommand);
messenger.attach(kRequest , onIdentifyRequest);
messenger.attach(kLed , onTurnLedOn);
messenger.attach(kHeading , onHeadingLockChanged);
// ------------------ C A L L B A C K S -----------------------
// Called when a received command has no attached function
void onUnknownCommand()
messenger.sendCmd(kDebug, "UNKNOWN COMMAND");
// Callback function to respond to indentify request. This is part of the
// Auto connection handshake.
void onIdentifyRequest()
char *szRequest = messenger.readStringArg();
if (strcmp(szRequest, "INIT") == 0) {
messenger.sendCmdStart(kRequest);
messenger.sendCmdArg("SPAD");
messenger.sendCmdArg(F("{DD7E3826-E439-4484-B186-A1443F3BC521}"));
// Device Name for UI
messenger.sendCmdArg("Arduino Demo");
messenger.sendCmdEnd();
return;
if (strcmp(szRequest, "PING") == 0) {
messenger.sendCmdArg("PONG");
messenger.sendCmdArg(messenger.readInt32Arg());
return;
if (strcmp(szRequest, "CONFIG") == 0) {
// Expose LED
messenger.sendCmdStart(kCommand);
messenger.sendCmdArg("ADD");
messenger.sendCmdArg(kLed);
messenger.sendCmdArg("leds/systemled"); // will become "SERIAL:<guid>/leds/systemled"
messenger.sendCmdArg("U8");
messenger.sendCmdArg("RW");
messenger.sendCmdArg("Led");
messenger.sendCmdArg("Toggle LED on/off");
// Request Heading Lock Dir Updates
messenger.sendCmdArg("SUBSCRIBE");
messenger.sendCmdArg(kHeading);
messenger.sendCmdArg("SIMCONNECT:AUTOPILOT HEADING LOCK DIR");
// tell SPAD.neXT we are done with config
messenger.sendCmd(kRequest, "CONFIG");
isReady = true;
// Make sure led is turned off and SPAD.neXt gets the value
setLED( LOW);
return;
// Callback to perform some action
void onTurnLedOn()
int32_t newLed = messenger.readInt32Arg();
if (newLed == 1)
setLED( HIGH);
messenger.sendCmd(kDebug, "LED COMMAND ON");
// For Demo Purpose:
// If we received a LED ON command, we set the heading in the sim to 180
messenger.sendCmd(kHeading, 180);
// New in 0.9.7.5
// For Demo purpose:
// Send FLAPS_UP command to simulation
messenger.sendCmd(kSimCommand, "SIMCONNECT:FLAPS_UP");
setLED( LOW);
messenger.sendCmd(kDebug, "LED COMMAND OFF");
// When we turned it off we unsubscribe from the heading lock for demo purpose
messenger.sendCmdArg("UNSUBSCRIBE");
// LED on if Heading > 180 else off;
void onHeadingLockChanged()
int32_t newHeading = messenger.readInt32Arg();
if (newHeading > 180)
setLED( HIGH);
messenger.sendCmd(kDebug, "HEADING > 180");
setLED( LOW);
messenger.sendCmd(kDebug, "HEADING < 180");
// Update system LED and post state back to SPAD.neXt
void setLED(int ledVal)
digitalWrite(ledPin, ledVal);
// Update Led-Data on SPAD.neXt
if ((ledVal != lastLedState) && isReady)
lastLedState = ledVal;
messenger.sendCmd(kLed, ledVal);
// ------------------ M A I N ----------------------
// Setup function
// 115200 is typically the maximum speed for serial over USB
// Attach my application's user-defined callback methods
attachCommandCallbacks();
// initialize the digital pin as an output.
pinMode(ledPin, OUTPUT);
// Turn LED on, will be turned off when connection to SPAD.neXt it up and running
setLED( HIGH);
// Loop function
// Process incoming serial data, and perform callbacks
messenger.feedinSerialData();
Here is a screenshot of the SPAD.next serial connection setup page. It should say "Connect/Disconnect" next to the COM9 entry, but it's not even recognizing a board is attached to that port.
