Hi Guys,
I've been working a project, which involves using a CMPS11 digital compass. I'm an amateur at programming, so please excuse me for my silly questions.
I'm building a robot, which need to know its heading accurately. I chose I2C communication as the update rate of the signals has to be at least 15hz.
I used this program to read out the orientation:
http://www.robot-electronics.co.uk/htm/cmps11i2c.htm
As far as I know, the "angle full" would give me the heading. For some reasons, It's not accurate at all, actually, pretty useless. I have no idea what it measures. Could you tell me how to yield the correct data from the sensor?
Regards,
Tamas
I found out how to solve the problem. I need to calibrate the sensor, but I have no idea how to do that. There are some guidelines on the net, but nothing exact.
Can someone tell me how to send the appropriate commands?
I tried to calibrate it today, but I couldn't make it to work. Can someone have a look at my code please?
#include <Wire.h>
#define ADDRESS 0x60
void setup(){
Wire.begin();
void loop(){
void calibrate(){
Wire.beginTransmission(ADDRESS);
Wire.write(0xF0);
delay(25);
Wire.write(0xF5);
delay(25);
Wire.write(0xF6);
Wire.endTransmission();
delay(25);
I don't normally use the Wire library, but it looks like you are not using it correctly. Spend some time with this documentation.
Hi Tomas,
Did you ever get this to work? I am trying to do the same thing (use the CMPS11 with I2C communication), but I cannot seem to get it to work. I am using the CMPS11 I2C sample code that is provided here:
https://www.robot-electronics.co.uk/files/arduino_cmps11_i2c.ino
But this code always gets held up on the "while(Wire.available() < 5); // Wait for all bytes to come back" line. Apparently no bytes ever come back!
I was wondering if you ran into any problems like this or could give me any advice of how to make this work. I am attaching a picture of my Arduino Uno and CMPS11 device so you can see my wiring too.
Thank you!
Jordan
