Cmu cam2 and arduino?
Hey
I have a friend who will sell me there cmu cam2 module on a pan tilt setup he has had it for 5 years and has not used it. But i was wondering if it would work on my arduino? also how much should i pay? i dont want to rip him off or get ripped off.
Thanks
Make it a project of the both of you, should work if you are friends :wink: He brings in the hardware and you do your part.
The Arduino can't handle video without special shields, but it can control the pan and tilt. So if the cam can be connected to e.g. a laptop and an arduino does the aiming, optionally controlled from the laptop KB or mouse, you have a very nice project.
kinda hard my friend live 7 hours away =(
robtillaart:
The CMUcam is made for interfacing with microcontrollers - it has its own on-board (and much more powerful) microcontroller with memory that handles the processing of the video frames and simply outputs data strings (depending on the setup for the functionality needed) via serial - for the most part. While it is possible (IIRC) to get the raw feed from the camera, it generally isn't needed, as the processing you would likely do on it can be handled by the CMUcam itself (it has built in color recognition, blob tracking, etc - all built in).
Arduino? - as you can tell from the above, you shouldn't have much of a problem interfacing the Arduino with the CMUcam and the pan/tilt platform (well, assuming the pan/tilt uses servos or some kind of serial link - if it uses something else, it may be more complex, but still possible I would think with the Arduino). Just go to the CMUcam site and get the manual (and example code; albeit perhaps not for the Arduino - you might find some AVR code, though):
http://www.cs.cmu.edu/~cmucam/
:slight_smile:
kinda hard my friend live 7 hours away smiley-cry
I did projects with people abroad without problems. You can share software over the internet so what is the problem?
Just download - TeamViewer – The Remote Connectivity Software - and get started to develop together ..
So what is the hard part ?
So how much is it worth? I know that we could use teamviewer but we dont want to. So please tell me how much it is worth! :slight_smile:
Thanks All :slight_smile:
I'd give $10 just to see if I could attach it to an arduino with ethernet shield to make a crude web cam.
