Cnc build
Hi all I am trying to control 5 motors for 3 axis with a cnc shield v 3 and a4988 stepper drivers I am new to it all and just after some advice to weather I can slave 2 axis with a additional driver wired to the board to mimic how the board slaves the 4th motor but un sure about how to wire it was thinking I could split of motor control from an axis then power in series with the cnc sheild power supply setting it up on small pcb of it's own with some jumper cables then solder when I get it to work any advice is much appreciated
Your keyboard is missing '.' and ',', I assume.
Begin by describing what you are attempting to build with 3 axes, but requires 5 stepper motors. Do you have the physical building done?
Paul
