Code 52 while installing Arduino
Hi! I'm getting an error when i try to install any Arduino (tested with Uno R3, and MEGA) I install the driver via the file arduino.inf, and i get and error (with "code52"), and a yellow /!\ in the peripherals list...
Thanks for help, and sorry for my bad english :D
"Code 52""windows......unsigned driver....."error on a W7X64 machine that my uno board was previously working,also device manager reports 28 com ports "in use".
After an hour and a half searching for a fix,reinstalling drivers...restarting many times....trying cables even disabling driver enforcement,which didn't work BTW
FINALLY
I wiped the com db from here"http://superuser.com/questions/408976/how-do-i-clean-up-com-ports-in-use"
Then deleted usbser.sys version 6.1.7601.18247 from C:\Windows\System32\drivers\ the working version that reinstalled is 6.1.7601.16385???
Then un/re installed arduino drivers from the arduino-1.0.5-r2 package.
Seems something installed an unsigned usbser.sys. I'm thinking it was probably LG PC Suite although the created date does not jibe.
My uno is now back working on com3.WTF
Hope it can help
Good Luck
Holy!
Been struggling with this all day. THANK you very much! Deleting the usbser.sys helped. While installing the new driver it created a new one.
Saved my day!
rellik1000, I deleted usbser.sys, uninstalled and reinstalled the drivers, and it worked!
Thank you so much, you beautiful genius!
Thank you for you Help “jaymz1097”, this is solution!!!
deleting usbser.sys, uninstalled and reinstalled IDE arduino, works¡¡¡
thanks so much
