Hello, i've been working on a code for a farming monitoring system that includes sensors and datalogger, finally read by a NFC App android (still in development).
The problem appeared when i finish the code and i went to compile...
Arduino show me this error: Low memory available, stability problems may occur.
So, i already try to optimize the code, deleting some lines and variables and i could reach the 36% of SRAM free. But still with 726 free bytes, the program is unstable and the serial monitor shows a confussion of ASCII characters like THIS.
If you guys, know how ressolve this problem withouth have to buy a Arduino Mega (i don't have the money), please help me! I'll be very gratefull.
Here's the code:
// Codigo Datalogger con fecha y hora para sensores DHT11 y YL-69
/* Librerias NFC y SPI */
#include <SPI.h> // Librerias NFC
#include "PN532_SPI.h"
#include "NfcAdapter.h"
#include "snep.h"
#include "NdefMessage.h"
/* Librerias Time, Sensores y SD */
#include <TimeLib.h> // Libreria para el tiempo virtual
#include <DHT11.h> // Libreria DHT11
#include <SD.h> // Libreria SD
/* Variables a usar */
File dataFile; // Archivo que creamos
DHT11 dht11(3); // Pin datos sensor
String dataString; // Linea con datos a grabar
String UIDtag;
int err; // Variable de error en la lectura
float temp, hum; // Variables del sensor 1
int humsuelo; // Variable convertida map porcentaje
Sd2Card card; //Variables para la SD
const int chipSelect = 4;
uint8_t ndefBuf[128]; //variables para comunicación P2P
String mensaje;
void setup(){
PN532_SPI interface(SPI, 10); // Se crea una interfaz serial para el chip PN532, en el pin 10
NfcAdapter nfc = NfcAdapter(interface);
Serial.begin(9600); // * Iniciamos comunicacion serial
setTime(02,20,00,13,10,2016); // * Configuramos la hora
pinMode(chipSelect, OUTPUT); // * Declaramos el pin ChipSelect como salida (modulo SD)
pinMode(5, INPUT_PULLUP); // * DHT11 GND
pinMode(6, INPUT); // * Definimos como entrada el pin 8 del arduino para el switch
pinMode(7, INPUT); // * Definimos como entrada el pin 8 del arduino para el switch
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(10,LOW); // Desactivo SS del modulo NFC
digitalWrite(4,HIGH); // Activo SS del modulo SD
nfc.begin();
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println(F("Fallo al iniciar"));
return;
Serial.println(F("Inicio CORRECTO"));
void loop(){
time_t t = now(); // Variable libreria tiempo
int humsueloraw = analogRead(A0); // Variable en raw del sensor 2 en la entrada A0
humsuelo = map(humsueloraw,0,1020,100,0);
dht11.read(hum, temp);
dataString=String(day(t)) + String("/") + String(month(t)) + String("/") + String(year(t)) + String(" ") + String(hour(t)) + String(":") + String(minute(t)) + String(", ") + String(temp) + String(" C, ") + String(hum) + String(" %") + String(", ") + String(humsuelo) + String(" %"); // Actualizamos la linea que guardaremos en el archivo de texto
SD.begin(chipSelect);
File dataFile=SD.open("lectura.txt", FILE_WRITE); // Creamos archivo de texto
if(dataFile){
dataFile.println(dataString); // Excribimos el contenido de "dataString" dentro del archivo de texto
dataFile.close(); // Cerramos la escritura dentro del archivo
Serial.println(dataString); // Mostramos en serial lo que se escribio
else{
Serial.println(F("Escritura erronea... ")); // Texto informativo de error de escritura
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
while(digitalRead(7)==LOW && digitalRead(6)==HIGH){
NFCtags();
while(digitalRead(7)==HIGH && digitalRead(6)==LOW){
NFCp2p();
void NFCtags(){
time_t t = now();
nfc.begin(); // Inicia modulo NFC
Serial.println(F("Acercar el Tag NFC a la antena")); // Texto informativo en puerto serial
if (nfc.tagPresent()){ // Lectura por si hay un elemento NFC presente
NfcTag tag = nfc.read(); // Lee el Tag(nfc.read) y lo convierte en un objeto (NfcTag)
//tag.print(); // Imprime el tipo de Tag NFC, UID (codifo unico de identificacion), y el mensaje grabado (si esta disponible)
UIDtag = String(day(t)) + String("/") + String(month(t)) + String("/") + String(year(t)) + String(" ") + String(hour(t)) + String(":") + String(minute(t)) + String(" - ") + String(tag.getUidString());
File dataFile=SD.open("tag.txt", FILE_WRITE); // Creamos archivo de texto
if(dataFile){
dataFile.println(UIDtag); // Excribimos el contenido de "dataString" dentro del archivo de texto
Serial.println(UIDtag); // Mostramos en serial lo que se escribio
else{
digitalWrite(8, LOW);
void NFCp2p(){
PN532_SPI pn532spi(SPI, 10);
SNEP nfc(pn532spi);
Serial.println(F("Acerque el dispositivo a la antena"));
mensaje=String("Este es el mensaje de prueba");
NdefMessage message = NdefMessage();
message.addUriRecord(mensaje);
int messageSize = message.getEncodedSize();
message.encode(ndefBuf);
nfc.write(ndefBuf, messageSize);
delay(3000);
Please excuse me for my bad english, i'm from Colombia and i do my best.
