Hi all,
I’ve got a simple motion-sensing nightlight for our bathroom, and I’m looking for ways to make it use less battery power. I find that the two 2000 mA*H AAs last about 14 days before I need to recharge them. It’s a PIR sensor that, when triggered, makes a single standard 5mm LED light up for 20 seconds – but only if the light sensor registers that the light level is below a given threshold. The MCU is an ATtiny85 bootloaded to 1 MHz (internal oscillator, BOD disabled).
I wouldn’t mind incorporating some sleep functionality into the ATtiny85 – ideally, I’d LOVE to have the MCU be asleep until motion is detected, then do a quick check of the light levels and light the LED if needed. Any ideas? I’ve used the watchdog timer for this chip in other applications; just unsure how I’d use it for this one where everything gets triggered off of the PIR sensor signal.
Here’s the code I’m currently using:
// ATMEL ATTINY85 / ARDUINO
// Ain0 (D 5) PB5 1| |8 Vcc
// Ain3 (D 3) PB3 2| |7 PB2 (D 2) Ain1
// Ain2 (D 4) PB4 3| |6 PB1 (D 1) pwm1
// GND 4| |5 PB0 (D 0) pwm0
const int LightSensorPin = 3; // analog in, to ADC3 for light sensor, pin 2 on ATtiny85
const int ledPin = 0;
const int LightLevelThreshold = 200;
const int PIRsensorPin = 4; // digital in, to ADC1 for light sensor, pin 7 on ATtiny85
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(LightSensorPin, INPUT); // declare photoresistor as input
pinMode(PIRsensorPin, INPUT); // declare PIR sensor as input
int rate = analogRead(LightSensorPin);
if (rate < LightLevelThreshold) // then too dark to see bowl
int val = digitalRead(PIRsensorPin); // read input value
if (val == HIGH) // check if the input is HIGH
analogWrite(ledPin, 255); // turn LED on if motion detected
delay(20000);
analogWrite(ledPin, 0); // turn LED off
digitalWrite(ledPin, LOW);
Thanks for the help!
Tom
