Code and Board Power Problem
I am writing simple code for a single channel ohmmeter, and I am actually incurring a problem. There is a variable called "raw" in my code which basically represents the amount of power being supplied to the board. My board receives power through a USB connection; however, a wire needs to be connected into a certain pin on the board in order to actually use that power.
My code for the ohmmeter wasn't working, so I decided to view the value of the raw variable both when I had connected that wire into the pin and when I disconnected that wire, and in the serial monitor, the variable, "raw," displayed the same value.
Can you guys please help me as I am confused about why that variable is returning a value even when no power is actually being supplied to the board?
Thanks!
Post code that reproduces your problem.
Post a schematic of your connections.
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
Which thread do you want to use?
http://forum.arduino.cc/index.php?topic=447715.msg3082205#msg3082205
Please do not double post.
Thanks.. Tom... :)
