Code Arrangement Help!
Hello! I’m back with a new problem hehe. So far I’ve been doing my project well then i suddenly cross a problem with it.
I think my code is a mess. I have XBEE and ESP8266 and a MOTOR. When i join the code for my esp8266 to the program. the XBEE is not working. But when i remove it, the XBEE is working and it triggers the motor.
Here’s a look at my code:
#include <SoftwareSerial.h>
SoftwareSerial XBee(10, 11); // RX, TX
SoftwareSerial esp(50, 52);
int relayPin = 4;
int stepPin = 5;
int dirPin = 6;
int enblPin = 7;
long Distance = 0;
const byte numChars = 32;
char receivedChars[numChars];   // an array to store the received data
boolean newData = false;
int dataNumber = 0;             // new for this version
  XBee.begin(9600); //SERIALS
  esp.begin(9600);
  esp.println("AT");
  response(3000);
  esp.println("AT+CIOBAUD=9600");
  response(1000);
  esp.println("AT+CWMODE=1");
  response(2000);
  esp.println("AT+CWJAP=\"Jebe\",\"12345678\"");
  response(10000);
  Serial.println("<Arduino is ready>");
  pinMode(relayPin, OUTPUT); //RELAY SERIAL
  digitalWrite(relayPin, HIGH);
  pinMode (stepPin, OUTPUT); //MOTOR SERIAL
  pinMode (dirPin, OUTPUT);
  pinMode (enblPin, OUTPUT);
  digitalWrite(stepPin, LOW);
  digitalWrite(dirPin, LOW);
  digitalWrite(enblPin, HIGH);
  static bool runningMotor1 = false;
  recvWithEndMarker();
  showNewNumber();
  delay(3000);
  if (!runningMotor1 && dataNumber <= 50)
  { runMotor1();
    runningMotor1 = true;
  if (runningMotor1 && dataNumber >= 51)
  { runMotor2();
  delay(3000);
  esp.println("AT+CIPSTART=\"TCP\",\"rmc.cloudsoftwarestudio.com\",80");
  response(5000);
  esp.println("AT+CIPSEND=80");
  response(2000);
  esp.print("GET Your Link with the IP address You Used ");
  esp.print(dataNumber);
  esp.println("\r\nabcd1234");
  response(5000);
void recvWithEndMarker() {
  static byte ndx = 0;
  char endMarker = '\n';
  char rc;
  if (XBee.available() > 0) {
    rc = XBee.read();
    if (rc != endMarker) {
      receivedChars[ndx] = rc;
      ndx++;
      if (ndx >= numChars) {
        ndx = numChars - 1;
    else {
      receivedChars[ndx] = '\0'; // terminate the string
      ndx = 0;
      newData = true;
void showNewNumber() {
  if (newData == true) {
    dataNumber = atoi(receivedChars);   // new for this version
    // Serial.print("This just in ... ");
    // Serial.println(receivedChars);
    //Serial.print("Data as Number ... ");    // new for this version
    Serial.print (dataNumber);     // new for this version
    Serial.println (" mm");
    newData = false;
void runMotor1() {
  //CLOCKWISE
    digitalWrite(relayPin, LOW);  // Turn Relay ON
    Serial.println("Relay is ON");
    for (long x = 0; x < 44800; x++)
      digitalWrite(stepPin, HIGH);
      delayMicroseconds(100);
      //Distance = Distance + 1;
  if (Distance == 44800);
  { if
    (digitalRead(dirPin) == HIGH)
      digitalWrite(dirPin, HIGH);
      digitalWrite(relayPin, HIGH); // Turn Relay Off
void runMotor2()
  //C-CLOCKWISE
      //  Distance = Distance + 1;
  { if
    (digitalRead(dirPin) == LOW)
      digitalWrite(relayPin, HIGH); //Turn Relay OFF
void response(int waitTime) {
  for (int i = 0 ; i < waitTime; i++)
  { if (esp.available() > 0)
    { char x = esp.read();
      Serial.print(x);
    delay(1);
The esp is the only thing that i see in the serial monitor. the printing of the values from the xbee are not showing and the part of this code
  showNewNumber();
  delay(3000);
  { runMotor1();
  { runMotor2();
i think is not satisfying.
any thoughts? THANKS!
-andrea
Only one instance of software serial can be used at once. I have not used it but this page seems to show a solution.
The best solution is to use an Arduino that has more than one hardware serial port, ie Mega (3 + USB).
groundFungus:
Only one instance of software serial can be used at once. I have not used it but[ this page](http://www.fiz-ix.com/2012/12/arduino-uno-with-multiple-software-serial-devices/) seems to show a solution.
Hello! Thanks for replying. I am currently using Arduino MEGA which has i think 3 serial ports? something like that. So i think using 2 software serial at the same time would work. Thanks!
No. You need HardwareSerial, not SoftwareSerial. The objects you’re looking for are Serial1, Serial2 and Serial3. Reference
As a general rule: don’t use SoftwareSerial.
(Unless you want a temporary debug output, for example.)
Pieter
Your codes both block execution terribly. Over 99.9% of the time they spend doing NOTHING and zip through the rest to block again. NOTHING means not running any other code but interrupts.
Don't use an interrupt to try and fix this. Learn about blocking code and how to never need to use a delay() again.
In my signature space below are 3 addresses to tutorials. You only need to check out the first one to see what & how.
PieterP:
No. You need HardwareSerial, not SoftwareSerial. The objects you're looking for are Serial1, Serial2 and Serial3. Reference
As a general rule: don't use SoftwareSerial.
Pieter
Hello! Thanks for replying. Does this mean that i should put my xbee and esp8266 on serial 1 and serial 2? if that's the case, should i remove the
SoftwareSerial esp(14, 15);
"SoftwareSerial" in the code?
I am new to using arduino in multiple tasking. hehe. Thanks!
Yes, remove the all of software serial stuff and use the harware ports (Serial1 and Serial2).
Pin numbers pretty much gave it away but you really should include in your question description what Arduino you use, as it often matters, like in this case.
You have three hardware Serial available. Use them.
  esp.begin(9600);
is replaced by:
  Serial1.begin(9600); // could be the Xbee
  Serial2.begin(9600); // then this would be the ESP
No, even simpler. Replace all of the code below:
With the following…
#define XBee Serial1
#define esp Serial2
Then the rest of your code will just work with no modification. Of course you should choose which Serial1/2/3 you prefer for each device.
  delay(3000);
Don't do this.
You need to have the parts of the program which deal with serial input called at least 10 times per second, every second. Preferably a few hundred times per second. Otherwise you will miss vital information.
Find Robin's tutorial on "Planning and implementing an Arduino program".
Hello, everyone! Thanks for your interest. <3 I did this. Look:
#define esp Serial3
#define XBee Serial2
int relayPin = 4;
int stepPin = 5;
int dirPin = 6;
int enblPin = 7;
long Distance = 0;
  esp.begin(9600);
my problem is that this part of the code
  showNewNumber();
  { runMotor1();
  { runMotor2();
is not satisfying. the only thing that can be seen in the serial monitor is the commands in esp.
Here is the sample of my output that is seen in the serial monitor
AT
OK
AT+CIOBAUD=9600
OK
AT+CWMODE=1
OK
AT+CWJAP=“Jebe”,“12345678”
0,CLOSED
OK
Relay is ON
Relay OFF
AT+CIPSTART=“TCP”,“rmc.cloudsoftwarestudio.com”,80
CONNECT
OK
AT+CIPSEND=80
OK
0
0
busy s…
SEND OK
AT+CIPSEND=80
OK
0
0
0 mm
busy s…
SEND OK
thanks!
-andrea
What Serial monitor? In the original sketch I don't see you print anything to Serial other than a "ready" message.
wvmarle:
Here is the code that prints the value coming in the xbee:
    newData = false;
and with the "dataNumber", the if condition should be satisfied, but nothing is happening with respect to that part. Thanks!
-andrea
wvmarle:
I thought that was why softserial was being used on a 328P board. At least it's not a G-shield!
As for Arduino Mega serial ports, there are 4. Serial, Serial1, 2 & 3. All of those can function as full speed master mode SPI ports, code and walkthrough tutorial are up on Nick Gammon's blogs, like with so much else.
autogation17:
Post the complete code for the latest version of your proogram.
...R
