Code behaves in unexpected ways
Hello I’m a newbie and this is my first post.
I’m having trouble with a chunk of code.
This code is suppose to detect a single pulse, two pulses 270 ms apart or two pulses 730 ms apart. Then briefly turn on the appropriate LED.
The really frustrating part is: it works about 1/3 of the time. I’d be grateful for any help. Here’s the code:
const int green = 13;
const int yellow1 = 10;
const int yellow2 = 9;
const int remote = 8;
unsigned long remoteTimer;
int remoteCycle;
pinMode(green, OUTPUT);
pinMode(yellow1, OUTPUT);
pinMode(yellow2, OUTPUT);
pinMode(remote, INPUT);
reset();
void reset() {
remoteTimer = 0;
digitalWrite(yellow1, LOW);
digitalWrite(yellow2, LOW);
digitalWrite(green, LOW);
unsigned long a = 300;
unsigned long b = 240;
unsigned long c = 760;
unsigned long d = 700;
if(remoteCycle == LOW && digitalRead(remote) == HIGH) {
if(remoteTimer == 0) {
remoteTimer = millis();
else {
if((millis() - remoteTimer) < a && (millis() - remoteTimer) > b) {
digitalWrite(yellow1, HIGH);
else if((millis() - remoteTimer) < c && (millis() - remoteTimer) > d) {
digitalWrite(yellow2, HIGH);
else {
digitalWrite(green, HIGH);
if((millis() - remoteTimer) > 1500 || (millis() - remoteTimer) < 0) {
reset();
remoteCycle = digitalRead(remote);
Thanks in advance!
The above can never be true as you are using unsigned longs
Mark
I’m sorry, I got lost in the conditional statements.
You could add some comments.
Please place your code between [code][/code] tags.
const int green = 13;         // LED turns on for a single pulse.
const int yellow1 = 10;       // LED turns on for a two pulses seperated by 270ms.
const int yellow2 = 9;        // LED turns on for a two pulses seperated by 730ms.
const int remote = 8;         // Pulse input.
unsigned long remoteTimer;    // Used to remember time of first pulse.
int remoteCycle;              // Used by loop to remember state of digitalRead(remote) for the next loop.
  // Set remoteTimer to 0 and turn off all LEDs.
  reset();
 * Set remoteTimer to 0 and turn off all LEDs.
void reset() {
  remoteTimer = 0;
 * The green LED turns on for a single pulse.
 * The first yellow LED turns on for a two pulses seperated by 270ms.
 * The second yellow LED turns on for a two pulses seperated by 730ms.
  // If and only if the digitalRead(remote) was LOW for the last loop and HIGH for this loop
     // If this is the first LOW to HIGH change (pulse).
     // If this is the second LOW to HIGH change (pulse).
     else {
        // If the second pulse was inbetween 240 to 300 ms.
        if((millis() - remoteTimer) < 300 && (millis() - remoteTimer) > 240) {
        //If the second pulse was inbetween 700 to 760 ms.
        else if((millis() - remoteTimer) < 760 && (millis() - remoteTimer) > 700) {
        // If there is no second pulse.
        else {
  // If 1500 ms has pasted since the first pulse set remoteTimer back to 0 and turn off all LEDs.
  if((millis() - remoteTimer) > 1500) {
     reset();
  // Store the current digitalRead(remote) state for comparison in the next loop.
What do your Serial.print()s tell you? Or, rather, what would they if you bothered having some?
