Code behaving oddly
I am building a Johnny 5 inspired robot. I have a track assembly, a humanoid torso,Arduino Mega with a sensor shield, L298 Motor Driver Module,Torobot servo driver board, PS2 Controller, HC 05 Bluetooth module, SRF04 unit and 1.3" OLED display. I have upgraded the Scanning "Radar" project to have duplex communication, and have added modes, speeds and a tilt function for the head. I have an FPV cam, Video TX, IMU and an IR ranging module to add as well. I am using a Finite State Machine that is switched by the PS2 controller by using a combination of buttons to give me a maximum of 16 states that I can call from the remote. I have many pieces of code written for each of the states. State 2 is the scanning code. The backbone (PS2 controller and FSM) works great until I put in the scanning code. When I run this sketch I can enter state 2 but switching out of 2 it makes me wait until both halves of the scan are finished before changing states. Here is the code. What am I missing.
void poll_controller() {
  ps2x.read_gamepad(false, vibrate);          //read controller and set large motor to spin at 'vibrate' speed
  //ps2x.Analog(PSAB_BLUE)ps2x.Button(PSB_START)
  if (ps2x.Analog(PSAB_GREEN)) {                 //will be TRUE as long as button is pressed
    if (ps2x.NewButtonState())              //will be TRUE if any button changes state (on to off, or off to on)
      if (ps2x.Button(PSB_L1))
        //Serial.println("Tri+L1 pressed");
        state = 1;
      if (ps2x.Button(PSB_R1))
        // Serial.println("Tri+R1 pressed");
        state = 2;
      if (ps2x.Button(PSB_L2))
        // Serial.println("Tri+L2 pressed");
        state = 3;
      if (ps2x.Button(PSB_R2))
        // Serial.println("Tri+R2 pressed");
        state = 4;
  if (ps2x.Analog(PSAB_RED)) {                 //will be TRUE as long as button is pressed
        state = 13;
      //Serial.println("Cir+L1 pressed");
        state = 14;
      //Serial.println("Cir+R1 pressed");
        state = 15;
      //Serial.println("Cir+L2 pressed");
        state = 16;
      //Serial.println("Cir+R2 pressed");
void scanner() {
  // Serial.println(state);
  // rotates the servo motor from 15 to 165 degrees
  for (int i = min_sweep; i <= max_sweep; i++) {
    Pan_Servo.write(i);
    //IMU_Data();
    Tilt_Servo.write(j);
    poll_controller();
    delay(sweep_rate);
    buttons();
    get_US_range();
    Serial.print(i); // Sends the current degree into the Serial Port
    Serial.print(","); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
    Serial.print(sonar.ping_result / US_ROUNDTRIP_CM); // Sends the distance value into the Serial Port
    Serial.print("."); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
  // Repeats the previous lines from 165 to 15 degrees
  for (int i = max_sweep; i > min_sweep; i--) {
    Pan_Servo.write(i);
    //IMU_Data();
    poll_controller();
    delay(sweep_rate);
    buttons();
    get_US_range();
    Serial.print(i);
    Serial.print(",");
    Serial.print(sonar.ping_result / US_ROUNDTRIP_CM);//Ranging data
    Serial.print(".");
  buttons();
  poll_controller();
I find it easier to send a debug message to the Serial Monitor for each type of button press.
You'll find out soon enough your logic error.
Yeah, I did that and see the button presses but the sonar finishes before responding
What are the values for min_sweep and max_sweep in below (probably 15 and 165 but not sure)
What is the value of sweep_rate in below
    delay(sweep_rate);
So that's a delay of 150 times how much?
Getting rid of the delay in favour of a millis() based approach will probably solve the problem.
PS
If you would have posted the complete code, I would not have had to ask the questions.
/*Johnny 5 code 4/12/2020
/*Author Lane Barry
/*-----( Import needed libraries )-----*/
// system states //
#define SLEEP        0
#define WAKE         1
#define SEARCH       2
#define DRIVE        3
#define MANIPULATE   4
#define CROUCH       5
#define STOW         6
#define SEQUENCE     7
#define MANUAL       8
#define ERROR        9
#define NAG          10
#include "U8glib.h"
U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NONE);  // I2C / TWI
#include <Servo.h>
#include <NewPing.h>
#define TRIGGER_PIN 3 // Arduino pin tied to trigger pin on ping sensor.
#define ECHO_PIN 4 // Arduino pin tied to echo pin on ping sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define beeper    53
int min_sweep = 20;
int max_sweep = 130;
int min_tilt = 0;
int max_tilt = 180;
int sweep_rate = 40;
float correct;
int k = 0;
int j = 90;
// Defines Trig and Ecko pins of the Ultrasonic Sensor
const int trigPin = 3;
const int echoPin = 4;
// Variables for the duration and the distance
long duration;
int distance;
Servo Pan_Servo; // Creates a servo object for controlling the servo motor
Servo Tilt_Servo; // Creates a servo object for controlling the servo motor
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
unsigned int pingSpeed = 50; // How frequently are we going to send out a ping (in milliseconds). 50ms would be 20 times a second.
unsigned long pingTimer; // Holds the next ping time.
char val; // Data received from the serial port
int command = 2;       // This is the command char, in ascii form, sent from the serial port
byte zero;
int state = 2;       // master variable for the state machine
int second; // declare time variables
int counter = 0;
#include <PS2X_lib.h>  //for v1.6
PS2X ps2x; // create PS2 Controller Class
int error = 0;
byte type = 0;
byte vibrate = 0;
// flip screen, if required
  u8g.setRot180();
  u8g.setFont(u8g_font_unifont);
  u8g.setColorIndex(1); // Instructs the display to draw with a pixel on.
u8g.firstPage();
  do {
    draw();
  } while( u8g.nextPage() );
  u8g.firstPage();
  do {
    draw2();
  u8g.firstPage();
do {
    draw3();
u8g.firstPage();
do {
    draw4();
  //CHANGES for v1.6 HERE!!! **************PAY ATTENTION*************
  error = ps2x.config_gamepad(13, 11, 10, 12, true, true); //setup pins and settings:  GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
  if (error == 0) {
    Serial.print("");
    //Serial.println("Found Controller, configured successful");
    // Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
    //Serial.println("holding L1 or R1 will print out the analog stick values.");
    //Serial.println("Go to www.billporter.info for updates and to report bugs.");
  else if (error == 1)
    Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips");
  else if (error == 2)
    Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips");
  else if (error == 3)
    //Serial.println("Controller refusing to enter Pressures mode, may not support it. ");
    Serial.print(".");
  //Serial.print(ps2x.Analog(1), HEX);
  type = ps2x.readType();
  switch (type) {
    case 0:
      Serial.println("Unknown Controller type");
    case 1:
      Serial.println("DualShock Controller Found");
      Serial.print("");
u8g.firstPage();
  do {
    draw5();
  u8g.firstPage();
  do {
    draw6();
  u8g.firstPage();
do {
    draw7();
    case 2:
      Serial.println("GuitarHero Controller Found");
  /*-----( scanning sonar )-----*/
  // ----------------------------------U/S Ranging-----------------------------------------
  pingTimer = millis(); // Start now.
  pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  //Serial.begin(115200);
  Pan_Servo.attach(5); // Defines on which pin is the servo motor attached
  Tilt_Servo.attach(6); // Defines on which pin is the servo motor attached
  //Tilt_Servo.write(45);
  // pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
  //initialize serial communications at a 9600 baud rate
  // Serial.begin(115200);
  //establishContact(); // send a byte to establish contact until receiver responds
  //initialize serial communications at a 115200 baud rate
  // Serial.print("Setup Finished");
  //Serial.println(state);
  poll_controller();
  switch (state)
    case SLEEP:
      HandleSLEEPState();
    case WAKE:
      HandleWAKEState();
    case SEARCH:
      HandleSEARCHState();
    case DRIVE:
      HandleDRIVEState();
    case MANIPULATE:
      HandleMANIPULATEState();
    case CROUCH:
      HandleCROUCHState();
    case STOW:
      HandleSTOWState();
      HandleSLEEPState();
    case ERROR:
      HandleERRORState();
    case MANUAL:
      HandleMANUALState();
    case NAG:
      HandleNAGState();
    default:
      Serial.print("Unknown State: ");
      allRelaysOff; // Should never get here
void HandleNAGState()
void HandleERRORState()
void HandleSEQUENCEState()
//check_buttons();
void HandleWAKEState()
  Pan_Servo.write(90);
  Tilt_Servo.write(90);
  poll_controller();
void HandleSEARCHState()
scanner();
void HandleDRIVEState()
Pan_Servo.write(130);
  Tilt_Servo.write(100);
  poll_controller();
void HandleMANIPULATEState()
Pan_Servo.write(40);
  Tilt_Servo.write(120);
  poll_controller();
void HandleCROUCHState()
//check_buttons();
void HandleSTOWState()
//check_buttons();
void HandleDRAINING2State()
void HandlePAUSE2State()
void HandleFILLING3State()
void HandleSTIRRING3State()
void HandleDRAINING3State()
void allRelaysOff() {
void HandleSTOPPEDState()
void HandleSLEEPState()
void HandleMANUALState()
void ABORT() {
void establishContact() {
while (Serial.available() <= 0) {
  Serial.print("A"); // send a capital A
  //aSerial.println("."); // send a capital A
void get_US_range() {
if (millis() >= pingTimer) { // pingSpeed milliseconds since last ping, do another ping.
  pingTimer += pingSpeed; // Set the next ping time.
  sonar.ping_timer(echoCheck); // Send out the ping, calls "echoCheck" function every 24uS where you can check the ping status.
// Do other stuff here, really. Think of it as multi-tasking.
poll_controller();
void echoCheck() { // Timer2 interrupt calls this function every 24uS where you can check the ping status.
// Don't do anything here!
if (sonar.check_timer()) { // This is how you check to see if the ping was received.
(Use code tags please, </> on the menu, Thanks, Moderator)
      state = 1;
      state = 2;
      state = 3;
      state = 4;
if (ps2x.Analog(PSAB_BLUE)) {                 //will be TRUE as long as button is pressed
      Serial.println("X+L1 pressed");
    state = 5;
      Serial.println("X+R1 pressed");
    state = 6;
      Serial.println("X+L2 pressed");
    state = 7;
      Serial.println("X+R2 pressed");
    state = 8;
if (ps2x.Analog(PSAB_PINK)) {                 //will be TRUE as long as button is pressed
      // Serial.println("Sq+L1 pressed");
      state = 9;
      //Serial.println("Sq+R1 pressed");
      state = 10;
      // Serial.println("Sq+L2 pressed");
      state = 11;
      //Serial.println("Sq+R2 pressed");
      state = 12;
      state = 13;
      state = 14;
      state = 15;
      state = 16;
void scanner() {
  Pan_Servo.write(i);
  //IMU_Data();
  poll_controller();
  delay(sweep_rate);
  buttons();
  get_US_range();
  Pan_Servo.write(i);
  //IMU_Data();
  poll_controller();
  delay(sweep_rate);
  buttons();
  get_US_range();
  Serial.print(i);
  Serial.print(",");
  Serial.print(".");
buttons();
poll_controller();
void buttons() {
if (Serial.available() > 0) { // If data is available to read,
  val = Serial.read(); // read it and store it in val
  if (val == 'r') //if we get a r Fast Sweep
  { sweep_rate = 2;
    // R_State = !R_State; //flip the ledState
    // digitalWrite(13, R_State);
  if (val == 't') //if we get a t
  { sweep_rate = 7;
    //T_State = !T_State; //flip the ledState Quick Sweep
    //digitalWrite(13, T_State);
  if (val == 'b') //if we get at b Medium Sweep
  { sweep_rate = 14;
    // B_State = !B_State; //flip the ledState
    // digitalWrite(13, B_State);
  if (val == 'e') //if we get a e Slow Sweep
  { sweep_rate = 30;
    //F_State = !F_State; //flip the ledState
    //digitalWrite(13, F_State);
  if (val == 'y') //if we get a y Full Sweep
    min_sweep = 40;
    max_sweep = 165;
  if (val == 'u') //if we get a u Wide Sweep
    min_sweep = 45;
    max_sweep = 140;
  if (val == 'i') //if we get at i Narrow Sweep
    min_sweep = 60;
    max_sweep = 120;
  if (val == 'o') //if we get a o Steer Sweep
    min_sweep = 75;
    max_sweep = 105;
  if (val == 'p') //if we get a p Beam Sweep
    min_sweep = 84;
    max_sweep = 96;
  if (val == 's') //if we get a s Stop Sweep
    min_sweep = 90;
    max_sweep = 90;
    sweep_rate = 10;
  if (val == 'd') //if we get a p Beam Sweep
    j = j - 1;
  if (val == 'f') //if we get a s Stop Sweep
    j = j + 1;
else {
void draw(){
u8g.drawStr( 0, 15, " INITILIZING");
void draw2(){
u8g.drawStr( 0, 35, " ROBOT");
void draw3(){
u8g.drawStr( 0, 55, " STAND BY");
void draw4(){
void draw5(){
u8g.drawStr( 0, 15, "CONTROLLER");
// u8g.drawStr( 0, 35, "  FOUND");
// u8g.drawStr( 0, 55, "ROBOT READY");
void draw6(){
void draw7(){
 u8g.drawRFrame(15, 20, 100, 30, 10);
state = 1;
state = 2;
state = 3;
state = 4;
state = 5;
state = 6;
state = 7;
state = 8;
state = 9;
state = 10;
state = 11;
state = 12;
state = 13;
state = 14;
state = 15;
state = 16;
void scanner() {
Pan_Servo.write(i);
//IMU_Data();
poll_controller();
delay(sweep_rate);
buttons();
get_US_range();
Pan_Servo.write(i);
//IMU_Data();
poll_controller();
delay(sweep_rate);
buttons();
get_US_range();
Serial.print(i);
Serial.print(",");
Serial.print(".");
buttons();
poll_controller();
void buttons() {
{ sweep_rate = 2;
{ sweep_rate = 7;
{ sweep_rate = 14;
{ sweep_rate = 30;
min_sweep = 40;
max_sweep = 165;
min_sweep = 45;
max_sweep = 140;
min_sweep = 60;
max_sweep = 120;
min_sweep = 75;
max_sweep = 105;
min_sweep = 84;
max_sweep = 96;
min_sweep = 90;
max_sweep = 90;
sweep_rate = 10;
j = j - 1;
j = j + 1;
else {
void draw(){
void draw2(){
void draw3(){
void draw4(){
void draw5(){
void draw6(){
void draw7(){
You will have to split your for-loops in small pieces.
In a first step, take the for loops out of the scanner function and put it in a function. E.g. call those new functions scanner15_165 and scanner165_15.
In each function, delete for(...) so you only have the body of the for-loop left.
Keep track of a counter (it will replace i of the for loop) using a static variable. E.g. call this counter e.g. sweepCount.
Your scanner15_165 function will now look like
  scan from min_sweep to max_sweep
  Returns:
    true when is sweep is completed, else false
bool scanner15_165()
  static int sweepCount = min_sweep;
  Pan_Servo.write(sweepCount);
  //IMU_Data();
  poll_controller();
  delay(sweep_rate);
  buttons();
  get_US_range();
  Serial.print(sweepCount); // Sends the current degree into the Serial Port
  sweepCnt++;
  if (sweepCnt == max_sweep)
    return true;
    return false;
Now you need to call this numerous times and each time you will do a little step from min_sweep to max_sweep. Once it has reached max_sweep, it will indicate that the operation completed.
Do the same thing for the scanning in the other direction; adjust the count logic.
Next you can implement a simple state machine in the scanner() function; one state to sweep from min to max and one state to sweep from max to min
void scanner() {
  // sweep direction; 0 indicates min to max, 1 indicates max to min
  static byte direction = 0;
  // if min to max
  if (direction == 0)
    // one little step; check to see if all steps have completed
    if (scanner15_165() == true)
      // if complete, change direction
      direction = 1;
  // else max to min
    // one little step, check to see if all steps have completed
    if (scanner165_15() == true)
      direction = 0;
  buttons();
  poll_controller();
You can probably get rid of the calls to buttons(), ps2x.read_gamepad() and poll_controller() lines in scanner15_165() and scanner165_15().
I have left the delay in both new functions; if you need a better responsiveness or are a perfectionist, use a millis() based implementation (probably) in scanner and remove the delays from the new functions.
Posted as a guideline.
