I am using this code to stop and start a midi sequencer. It also outputs a sync pulse which works very well. However, the stop start button only controls midi and not the sync pulse. Can someone please help me modify the code so that midi and sync pulse output are both controlled with the start stop button?
#include <TimerOne.h>
* For all features: if you do not define the pin, the feature will be disabled!
* FEATURE: TAP BPM INPUT
#define TAP_PIN 2
#define TAP_PIN_POLARITY RISING
#define MINIMUM_TAPS 4
#define EXIT_MARGIN 150 // If no tap after 150% of last tap interval -> measure and set
* FEATURE: DIMMER BPM INPUT
#define DIMMER_INPUT_PIN A0
#define DIMMER_CHANGE_MARGIN 20 // Big value to make sure this doesn't interfere. Tweak as needed.
* FEATURE: DIMMER BPM INCREASE/DECREASE
//#define DIMMER_CHANGE_PIN A1
//#define DEAD_ZONE 50
//#define CHANGE_THRESHOLD 5000
//#define RATE_DIVISOR 30
* FEATURE: BLINK TEMPO LED
#define BLINK_OUTPUT_PIN 5 // 5
#define BLINK_PIN_POLARITY 0 // 0 = POSITIVE, 255 - NEGATIVE
#define BLINK_TIME 4 // How long to keep LED lit in CLOCK counts (so range is [0,24])
* FEATURE: SYNC PULSE OUTPUT
#define SYNC_OUTPUT_PIN 9 // Can be used to drive sync analog sequencer (Korg Monotribe etc ...)
#define SYNC_PIN_POLARITY 0 // 0 = POSITIVE, 255 - NEGATIVE
* FEATURE: Send MIDI start/stop
#define START_STOP_INPUT_PIN 7
#define START_STOP_PIN_POLARITY 0 // 0 = POSITIVE, 1024 = NEGATIVE
#define MIDI_START 0xFA
#define MIDI_STOP 0xFC
#define DEBOUNCE_INTERVAL 500L // Milliseconds
* FEATURE: EEPROM BPM storage
#define EEPROM_ADDRESS 0 // Where to save BPM
#ifdef EEPROM_ADDRESS
#include <EEPROM.h>
#endif
* FEATURE: MIDI forwarding
#define MIDI_FORWARD
* FEATURE: TM1637 display BPM output
#define TM1637_DISPLAY
#ifdef TM1637_DISPLAY
#include <TM1637Display.h>
#define TM1637_CLK_PIN 3
#define TM1637_DIO_PIN 4
#define TM1637_BRIGHTNESS 0x0f
#endif
* GENERAL PARAMETERS
#define MIDI_TIMING_CLOCK 0xF8
#define CLOCKS_PER_BEAT 24
#define MINIMUM_BPM 400 // Used for debouncing
#define MAXIMUM_BPM 3000 // Used for debouncing
long intervalMicroSeconds;
int bpm; // BPM in tenths of a BPM!!
boolean initialized = false;
long minimumTapInterval = 60L * 1000 * 1000 * 10 / MAXIMUM_BPM; // 10
long maximumTapInterval = 60L * 1000 * 1000 * 10 / MINIMUM_BPM; // 10
volatile long firstTapTime = 0;
volatile long lastTapTime = 0;
volatile long timesTapped = 0;
volatile int blinkCount = 0;
int lastDimmerValue = 0;
boolean playing = false;
long lastStartStopTime = 0;
TM1637Display display(TM1637_CLK_PIN, TM1637_DIO_PIN);
uint8_t tm1637_data[4] = {0x00, 0x00, 0x00, 0x00};
#endif
#ifdef DIMMER_CHANGE_PIN
long changeValue = 0;
#endif
Serial.begin(38400);
// Set MIDI baud rate:
Serial1.begin(31250);
// Set pin modes
#ifdef BLINK_OUTPUT_PIN
pinMode(BLINK_OUTPUT_PIN, OUTPUT);
#endif
#ifdef SYNC_OUTPUT_PIN
pinMode(SYNC_OUTPUT_PIN, OUTPUT);
#endif
#ifdef DIMMER_INPUT_PIN
pinMode(DIMMER_INPUT_PIN, INPUT);
#endif
#ifdef START_STOP_INPUT_PIN
pinMode(START_STOP_INPUT_PIN, INPUT);
#endif
// Get the saved BPM value from 2 stored bytes: MSB LSB
bpm = EEPROM.read(EEPROM_ADDRESS) << 8;
bpm += EEPROM.read(EEPROM_ADDRESS + 1);
if (bpm < MINIMUM_BPM || bpm > MAXIMUM_BPM) {
bpm = 1200; // 1200
#endif
#ifdef TAP_PIN
// Interrupt for catching tap events
attachInterrupt(digitalPinToInterrupt(TAP_PIN), tapInput, TAP_PIN_POLARITY);
#endif
// Attach the interrupt to send the MIDI clock and start the timer
Timer1.initialize(intervalMicroSeconds);
Timer1.setPeriod(calculateIntervalMicroSecs(bpm));
Timer1.attachInterrupt(sendClockPulse);
// Initialize dimmer value
lastDimmerValue = analogRead(DIMMER_INPUT_PIN);
#endif
display.setBrightness(TM1637_BRIGHTNESS);
setDisplayValue(bpm);
#endif
long now = micros();
#ifdef TAP_PIN
* Handle tapping of the tap tempo button
if (timesTapped > 0 && timesTapped < MINIMUM_TAPS && (now - lastTapTime) > maximumTapInterval) {
// Single taps, not enough to calculate a BPM -> ignore!
// Serial.println("Ignoring lone taps!");
timesTapped = 0;
} else if (timesTapped >= MINIMUM_TAPS) {
long avgTapInterval = (lastTapTime - firstTapTime) / (timesTapped - 1);
if ((now - lastTapTime) > (avgTapInterval * EXIT_MARGIN / 100)) {
bpm = 60L * 1000 * 1000 * 10 / avgTapInterval; // 10 Change this number to alter tap (1/4, 1/8 etc!)
updateBpm(now);
// Update blinkCount to make sure LED blink matches tapped beat
blinkCount = ((now - lastTapTime) * 24 / avgTapInterval) % CLOCKS_PER_BEAT;
timesTapped = 0;
#endif
* Handle change of the dimmer input
int curDimValue = analogRead(DIMMER_INPUT_PIN);
if (curDimValue > lastDimmerValue + DIMMER_CHANGE_MARGIN
|| curDimValue < lastDimmerValue - DIMMER_CHANGE_MARGIN) {
// We've got movement!!
bpm = map(curDimValue, 0, 1024, MINIMUM_BPM, MAXIMUM_BPM);
updateBpm(now);
lastDimmerValue = curDimValue;
#endif
int curDimValue = analogRead(DIMMER_CHANGE_PIN);
if (bpm > MINIMUM_BPM && curDimValue < (512 - DEAD_ZONE)) {
int val = (512 - DEAD_ZONE - curDimValue) / RATE_DIVISOR;
changeValue += val * val;
} else if (bpm < MAXIMUM_BPM && curDimValue > (512 + DEAD_ZONE)) {
int val = (curDimValue - 512 - DEAD_ZONE) / RATE_DIVISOR;
changeValue = 0;
if (changeValue > CHANGE_THRESHOLD) {
bpm += curDimValue < 512 ? -1 : 1;
updateBpm(now);
changeValue = 0;
#endif
* Check for start/stop button pressed
boolean startStopPressed = digitalRead(START_STOP_INPUT_PIN) == HIGH;
if (startStopPressed && (lastStartStopTime + (DEBOUNCE_INTERVAL * 1000)) < now) {
startOrStop();
lastStartStopTime = now;
#endif
#ifdef MIDI_FORWARD
* Forward received serial data
while (Serial1.available()) {
int b = Serial1.read();
Serial1.write(b);
#endif
void tapInput() {
if (now - lastTapTime < minimumTapInterval) {
return; // Debounce
if (timesTapped == 0) {
firstTapTime = now;
timesTapped++;
lastTapTime = now;
Serial.println("Tap!");
void startOrStop() {
if (!playing) {
Serial.println("Start playing");
Serial1.write(MIDI_START);
Serial.println("Stop playing");
Serial1.write(MIDI_STOP);
playing = !playing;
void sendClockPulse() {
// Write the timing clock byte
Serial1.write(MIDI_TIMING_CLOCK);
blinkCount = (blinkCount + 1) % 12; //CLOCKS_PER_BEAT;
if (blinkCount == 0) {
// Turn led on
analogWrite(BLINK_OUTPUT_PIN, 255 - BLINK_PIN_POLARITY);
#endif
// Set sync pin to HIGH
analogWrite(SYNC_OUTPUT_PIN, 255 - SYNC_PIN_POLARITY);
#endif
if (blinkCount == 1) {
// Set sync pin to LOW
analogWrite(SYNC_OUTPUT_PIN, 0 + SYNC_PIN_POLARITY);
#endif
if (blinkCount == BLINK_TIME) {
// Turn led on
analogWrite(BLINK_OUTPUT_PIN, 0 + BLINK_PIN_POLARITY);
#endif
void updateBpm(long now) {
// Update the timer
long interval = calculateIntervalMicroSecs(bpm);
Timer1.setPeriod(interval);
// Save the BPM in 2 bytes, MSB LSB
EEPROM.write(EEPROM_ADDRESS, bpm / 256);
EEPROM.write(EEPROM_ADDRESS + 1, bpm % 256);
#endif
Serial.print("Set BPM to: ");
Serial.print(bpm / 10); // 10
Serial.print('.');
Serial.println(bpm % 10);
#endif
long calculateIntervalMicroSecs(int bpm) {
// Take care about overflows!
return 60L * 1000 * 1000 * 10 / bpm / CLOCKS_PER_BEAT; // 10 before bpm
void setDisplayValue(int value) {
tm1637_data[0] = value >= 1000 ? display.encodeDigit(value / 1000) : 0x00;
tm1637_data[1] = value >= 100 ? display.encodeDigit((value / 100) % 10) : 0x00;
tm1637_data[2] = value >= 10 ? display.encodeDigit((value / 10) % 10) : 0x00;
tm1637_data[3] = display.encodeDigit(value % 10);
display.setSegments(tm1637_data);
#endif
looks like when the START_STOP_INPUT_PIN toggles, startOrStop() is invoked which toggles the MIDI_START pin and toggle playing which isn't used elsewhere.
i don't see any actions associated with "sync pulse"
Thanks for your help... If I understand correctly, should this part be placed inside its own function?
// Turn led on
#endif
#endif
#endif
// Turn led on
#endif
Am I correct in understanding that when the button is pressed this function void startOrStop() is called? and that I need to create a new function to control the sync output pin at the same time?
After a little experimentation I've kept the blink output within the original void sendClockPulse() I want to keep the LED's visual pulse constantly operating regardless of whether the button is pressed or not.
// Turn led on
#endif
// Turn led on
#endif
I have extracted sync output from it though to create a new separate function.
void sendSyncPulse() {
#endif
#endif
If this is correct, how do I call this within void startOrStop()
but it's not clear if sendClockPulse() just needs to be done once when the button is pressed or if it needs to be invoked periodically. it looks like that function may be triggered by an interrupt
should the Timer1 interrupt be disabled when not playing? i don't know how this code is intended to work
I can't say either as I never wrote it and my skills aren't great with programming. Essentially the sync out pin is giving me a pulse which I'm using to start and stop a sequencer that only requires that simplicity. I just need to turn that pin on or off somehow when the button is pressed.
Ok thanks blh64. I wasn't sure how to apply what you had meant but I see it now. Ok, so I tried that and it works. However, the blink output and the sync output now go out of time with the midi or rather, they don't start in time with the midi on each button press. I'm wondering if Timer1 shouldn't be stopped because of this but more specifically be able to stop blink and sync output by turning off the pins? Does that make sense?
Thanks blh64. That also works. However, I realize there is a flaw in this program altogether. When the button is pressed, midi begins immediately, irrespective of the pulse from the sync output. For devices connected to the sync output and midi to start on the first beat of a sequence together, midi out would have to wait until sync out is at 5v. Does that make sense?
I think the problem is the variable blinkCount. It needs to get reset to 0 when you start so you do get a sync pulse when MIDI starts...
[edit] blinkCount needs to be reset to 11 so it gets incremented and %12 which will be 0 and force a synce pulse
#define TAP_PIN 2
#include <EEPROM.h>
#endif
#endif
GENERAL PARAMETERS
#endif
#endif
// Set pin modes
#endif
#endif
#endif
#endif
bpm = 1200; // 1200
#endif
#ifdef TAP_PIN
#endif
#endif
#endif
#ifdef TAP_PIN
timesTapped = 0;
updateBpm(now);
timesTapped = 0;
#endif
updateBpm(now);
#endif
changeValue = 0;
updateBpm(now);
changeValue = 0;
#endif
startOrStop();
#endif
#ifdef MIDI_FORWARD
Serial1.write(b);
#endif
void tapInput() {
return; // Debounce
firstTapTime = now;
timesTapped++;
lastTapTime = now;
if (!playing) {
blinkCount = 11; // force sync pulse right now
playing = !playing;
// Turn led on
#endif
if ( playing ) analogWrite(SYNC_OUTPUT_PIN, 255 - SYNC_PIN_POLARITY);
#endif
#endif
// Turn led on
#endif
// Update the timer
#endif
Serial.print('.');
#endif
#endif
edit #2. You might need to reset TimesTapped back to 0 as well when you start. If you do not, blinkCount could get altered on the next iteration of loop() before Timer1 fires and then the sync may not happen. This is all theory on my part since things would have to happen rather quickly (a couple of taps, the stop button pressed, then start).
Thanks blh64. That works perfectly now and everything is in sync.
As you have suggested to reset TimesTapped back to 0 at the start of each button press, how might I write that in please? When the tap tempo button is pressed 4 times the new tempo causes midi and pulse to go out of sync whilst playing. I s this what you meant could happen in edit#2?
C'mon now. I believe you can figure out how to set a variable equal to 0. If you can't, you need to take some time and learn C/C++ and study the examples in the IDE.
Hint: it is at the same location you reset blinkCount.
